  2. Functional Verification
  3. Tagging uvm_errors in waveform file for post-processing
  • Subscribers 67
  • Views 6890
antmarzam
antmarzam over 2 years ago
Do anyone know if it's possible in simvision waveform viewer to see a timestamp of where uvm_errors/$errors occurred in a simulation via post-processing?
Cheers,
Antonio
  • Doug Koslow
    Doug Koslow over 2 years ago
    Hi Antonio,
    There is a feature in Verisium Debug to send any log file message (not just UVM errors) from its "SmartLog" tool to the waveform, and a waveform trace will be plotted on-the-fly with a transition every time that message was generated. Here is a screenshot showing that for a UVM_INFO message:
    I strongly encourage you to upgrade from SimVision to Verisium Debug. I think you will find it's a great debug tool. Feel free to reach out to your Cadence AE to find out more  about it.
    You can also find more information about it here.
    Thanks.
    - Doug
  • antmarzam
    antmarzam over 2 years ago in reply to Doug Koslow
    Hi Doug,
    Thanks for your reply.
    I didn't know about Verisium Debug, I'll investigate if we can use it!
    Does the smartlog tool also annotates the waveform for post-processing, or during live-debugging?
    In addition, do you know if Simvision provides this feature? Or is it just a new feature added to Verisium?
    Cheers,
    Antonio
  • Doug Koslow
    Doug Koslow over 2 years ago in reply to antmarzam
    Hi Antonio,
    Yes, that feature is supported for both post process and interactive debug.
    It is a feature of Verisium Debug and not supported in SimVision.
    Thanks.
    - Doug
