  2. Functional Verification
  3. incorrect output of multiplication in jaspergold
  • Subscribers 67
  • Views 7786
Anubhav8136
Anubhav8136 over 1 year ago
I want to use jaspergold to formally verify functionality of my custom multiplier. I am computing the expected result using A*B to check against output of my multiplier. Here, A and B are two logic signed operands. However, jaspergold is performing the operation A*B incorrectly.
I have reproduced this issue using the attached example. JasperGold compiles and elaborates the module and subsequently runs a formal proof. The tool raises a counterexample to assertion whose screenshot is attached below:
I simulated the same example using xrun and it was giving the correct product output in simvision waveform. Please help me resolve this issue. I am using 2023.03 version of Jasper Apps.
Thanks and regards
Anubhav Agarwal
  • StephenH
    StephenH over 1 year ago
    Hi Anubhav. We cannot provide proper tool support in this forum, please could you login to support.cadence.com and file a service request along with a testcase that can reproduce the issue. The support team can then work with you to understand whether the behaviour you're seeing is expected or not, and work with R&D to get a fix if the behaviour of the tool isn't correct.
  • ErikSeligman
    ErikSeligman over 1 year ago
    Anubhav-- A common issue that may cause your observation is the fact that Jasper elaboration automatically blackboxes multipliers (ignoring all their internal logic)-- this is because multiplication is often very difficult to verify in model checking tools, and usually the user is trying to verify the control logic around the multiplier rather than the multiplication op itself.
    For some small examples you might be OK though.   To prevent your multiply from being blackboxed, you can elaborate with the added option "-bbox_mul <N>" to force the tool to only blackbox multipliers above size <N>.
    (For full verification of datapath operations, it's usually better to use Jasper C2RTL.  See https://www.cadence.com/en_US/home/tools/system-design-and-verification/formal-and-static-verification/jasper-c-formal-verification.html for more info.)
