  2. RF Design
  3. CPW ports
  • Subscribers 63
  • Views 6120
CPW ports
ArbLouis
ArbLouis over 1 year ago
Hi, in EMX I'm trying to define the ports of a CPW line as suggested in one document of the support area (i.e. P1:Gright,Gleft). The EMX simulation works fine. When I generate the schematic, I get this:
Basically, the two ground ports of each end of the CPW are properly defined as a unique node (e.g. G2_1, G2_2).
However, when I try a simulation I get this error:
I hope you can help me. Thanks.
    That's a bit odd. Have you modified the schematic_nport view since creating it? I would suggest opening the schematic_nport view and doing a check-and-save as the message suggests and seeing if that resolves it.
    If not, please contact customer support.
