  2. Functional Verification
  3. Using Xcelium, xrun -nogui option, where are the simulation...
  • Subscribers 67
  • Views 8225
Using Xcelium, xrun -nogui option, where are the simulation results
Stephen491
Stephen491 over 2 years ago
I'm completely new to Cadence. I've been able to run a very simple simulation with the -gui option. Simvision opens, I add the variables to the waveform viewer, and press run. All is good.
I don't understand the flow when using the -nogui option. It appears that the simulation runs and returns control to the OS. When I launch Simvision, is there a database or file that I can open to display the already-simulated data?
My command is of the form:
xrun -gui -64bit -sv -access +rwc -top tb_top.sv <src files>
  • Stephen491
    The case where I'm confused is when I omit -gui.
  • StephenH
    StephenH over 2 years ago
    The default in batch mode is to run till the end of the test and exit. Unless you ask it to, the simulator won't probe waveforms to a file.
    You have various choices including:
    • Run with Tcl interactive mode by adding -tcl to your xrun command
    • Run in batch mode with a Tcl script to control the simulation (-input your_script.tcl)
    If you create a Tcl file and add the relevant probing commands then you can use the GUI in post-processing mode after the simulation ends.
    The simplest probing command would be something like:
    probe -create -shm [scope -tops] -all -depth to_cells
    But I would advise you to read the documentation for the probe command to fully understand what the options are, to get what you need for your actual debugging requirements.
