  2. Functional Verification
  3. Using Vmanager Pre-Script to launch a timed script
  • Subscribers 67
  • Views 7134
Montana Tools
Montana Tools over 1 year ago
I would like to send an update about a vmanager regression status x days after the regression has been run. In the current environment, the vmanager regression is creating a new filepath for logs automatically based on regression name/date, so I can't use a cron job to gather logs, as the log location is not known.
I tried to use the pre session script to launch a detached shell script that would run after a delay, but when the pre_script runs, it waits until everything is completed before finishing and moving on to starting the regression.
Here is the test pre_script I am using:
#!/bin/sh
echo "pre_script start"
delay_script "FIRST" 1
nohup delay_script "SECOND" 30 & disown
delay_script "THIRD" 1
echo "pre_script end"
exit 0
Here is the test delay_script I am using:
#!/bin/sh
echo "Starting $1"
sleep $2
echo "Ending $1"
Here is the script output when run from terminal. After the "pre_script end", I get control back.
Here is the script output when run from vmanager. There is no "nohup", and the pre_session phase doesn't complete until all the delay scripts complete.
My question is, is there a better way to achieve my goal here? (The goal being to run a script from the vmanager log directory automatically x days after the regression). I think I could use the pre_script to send directory information for an auxiliary cron job to pick up, but I would prefer to not have to have extra cronjobs needed for this.
  • StephenH
    StephenH over 1 year ago
    What's the purpose of launching some script after a delay? If this is just for cleaning up old data, note that vManager has this facility built-in. Refer to Cadence Verisium Manager User Guide -- Analyzing Runs and Failures - Defining Eviction Policy (Database Cleanup) in the documentation.
  • Montana Tools
    Montana Tools over 1 year ago in reply to StephenH
    There are regressions with sims that have long run times (~3-7 days), and I would like to get the overall regression status sent automatically after a time, but before the full regression finishes. If there is a way to launch a script after a certain percentage of the regression completes, that would be ideal (right now I just have the pre and post script, which are 0% and 100% completion).
