  2. Logic Design
  3. Conformal CEC checking
  • Subscribers 63
  • Views 8594
Sameerpy
Sameerpy over 1 year ago
Below is showing my Master.v
///////ALU
module ALU (
    input [31:0] A,B,
    input[3:0] alu_control,
    output reg [31:0] alu_result,
    output reg zero_flag
    always @(*)
    begin
        // Operating based on control input
        case(alu_control)
        4'b0001: alu_result = A+B;
        4'b0010: alu_result = A-B;
        4'b0011: alu_result = A*B;
        4'b0100: alu_result = A|B;
        4'b0101: alu_result = A&B;
        4'b0110: alu_result = A^B;
        4'b0111: alu_result = ~B;
        4'b1000: alu_result = A<<B;
        4'b1001: alu_result = A>>B;
        4'b1010: begin
            if(A<B)
            alu_result = 1;
            else
            alu_result = 0;
        end
        default: alu_result = A+B;
        endcase
        // Setting Zero_flag if ALU_result is zero
        if (alu_result)
            zero_flag = 1'b1;
        else
            zero_flag = 1'b0;
    end
endmodule
/////CONTROL UNIT
Control unit controls takes opcode, funct7, funct3 of the instruction code to determine
and control regwrite in IFU, alu control in ALU to execute proper instruction
module CONTROL(
    input [4:0] opcode,
    output reg [3:0] alu_control,
    output reg regwrite_control,memread_control,memwrite_control
    always @(opcode)
    begin
       case(opcode)
        5'b00001: begin alu_control=4'b0001;  //add
        regwrite_control=1; memread_control=0; memwrite_control=0;
        end
        5'b00010: begin alu_control=4'b0010;  ///sub
        end
        5'b00011: begin alu_control=4'b0011;  //mul
        regwrite_control=0; memread_control=0; memwrite_control=1;
        end
        5'b00100: begin alu_control=4'b0100;  ///OR
        end
        5'b00101: begin alu_control=4'b0101;  ///AND
        end
        5'b00110: begin alu_control=4'b0110;  ///XOR
        end
        5'b00111: begin alu_control=4'b0111;  ///NOT
        end
        5'b01000: begin alu_control=4'b1000;  //SL
        regwrite_control=1; memread_control=1; memwrite_control=0;
        end
        5'b11001: begin alu_control=4'b1001;  //SR
        end
        5'b01010: begin alu_control=4'b1010;  //COMPARE
        end
        //5'b11010: begin ALU_control=4'b0000;  //SW
        //regwrite_control=1; memread_control=0; memwrite_control=0;
        //end
        //5'b01010: begin ALU_control=4'bxxxx;  //LW
        //regwrite_control=0; memread_control=0; memwrite_control=1;
        //end
        default : begin alu_control = 4'b0001;
        end
        endcase
    end
endmodule
//////DATA MEMORY
module Data_Mem(
input clock, rd_mem_enable, wr_mem_enable,
input [11:0] address,
input [31:0] datawrite_to_mem,
output reg [31:0] dataread_from_mem );
reg [31:0] Data_Memory[8:0];
initial begin
    Data_Memory[0] = 32'hFFFFFFFF;
    Data_Memory[1] = 32'h00000001;
    Data_Memory[2] = 32'h00000005;
    Data_Memory[3] = 32'h00000003;
    Data_Memory[4] = 32'h00000004;
    Data_Memory[5] = 32'h00000000;
    Data_Memory[6] = 32'hFFFFFFFF;
    Data_Memory[7] = 32'h00000000;
    //Data_Memory[8] = 32'h00000008;
    //Data_Memory[9] = 32'h00000009;
    //Data_Memory[10] = 32'h0000000A;
    //Data_Memory[11] = 32'h0000000B;
    //Data_Memory[12] = 32'h0000000C;
    //Data_Memory[13] = 32'h0000000D;
    //Data_Memory[14] = 32'h0000000E;
    //Data_Memory[15] = 32'h0000000F;
    //Data_Memory[16] = 32'h00000010;
    //Data_Memory[17] = 32'h00000011;
    //Data_Memory[18] = 32'h00000012;
    //Data_Memory[19] = 32'h00000013;
    //Data_Memory[20] = 32'h00000014;
    //Data_Memory[21] = 32'h00000015;
    //Data_Memory[22] = 32'h00000016;
    //Data_Memory[23] = 32'h00000017;
    //Data_Memory[24] = 32'h00000018;
    //Data_Memory[25] = 32'h00000019;
    //Data_Memory[26] = 32'h0000001A;
    //Data_Memory[27] = 32'h0000001B;
    //Data_Memory[28] = 32'h0000001C;
    //Data_Memory[29] = 32'h0000001D;
    //Data_Memory[30] = 32'h0000001E;
    Data_Memory[31] = 32'h0000001F;
    end
    always@(posedge clock) begin
       if(wr_mem_enable) begin
            Data_Memory[address] <= datawrite_to_mem;
       end
       else if(rd_mem_enable) begin
               dataread_from_mem <= Data_Memory[address];
       end
       else begin
               dataread_from_mem <= 32'h00000000;
       end
    end
endmodule
/////INST MEM
module INST_MEM(
    input [31:0] PC,
    input reset,
    output [31:0] Instruction_Code
    reg [7:0] Memory [43:0]; // Byte addressable memory with 32 locations
    assign Instruction_Code = {Memory[PC+3],Memory[PC+2],Memory[PC+1],Memory[PC]};
    initial begin
            // Setting 32-bit instruction: add t1, s0,s1 => 0x00940333
            Memory[3] = 8'b0000_0000;
            Memory[2] = 8'b0000_0001;
            Memory[1] = 8'b0111_1100;
            Memory[0] = 8'b0000_0001;
            // Setting 32-bit instruction: sub t2, s2, s3 => 0x413903b3
            Memory[7] = 8'b0000_0000;
            Memory[6] = 8'b0000_0110;
            Memory[5] = 8'b1000_1111;
            Memory[4] = 8'b1110_0010;
            // Setting 32-bit instruction: mul t0, s4, s5 => 0x035a02b3
            Memory[11] = 8'b0000_0000;
            Memory[10] = 8'b0000_0101;
            Memory[9] = 8'b0111_1100;
            Memory[8] = 8'b0000_0011;
            // Setting 32-bit instruction: or t3, s6, s7 => 0x017b4e33
            Memory[15] = 8'b1111_1111;
            Memory[14] = 8'b1111_0100;
            Memory[13] = 8'b1010_0000;
            Memory[12] = 8'b1010_0100;
            // Setting 32-bit instruction: and
            Memory[19] = 8'b0000_0000;
            Memory[18] = 8'b0010_1001;
            Memory[17] = 8'b0001_1101;
            Memory[16] = 8'b0010_0101;
            // Setting 32-bit instruction: xor
            Memory[23] = 8'b0000_0000;
            Memory[22] = 8'b0001_1000;
            Memory[21] = 8'b0000_1101;
            Memory[20] = 8'b0110_0110;
            // Setting 32-bit instruction: not
            Memory[27] = 8'b0000_0000;
            Memory[26] = 8'b0010_1001;
            Memory[25] = 8'b0011_1101;
            Memory[24] = 8'b1100_0111;
            // Setting 32-bit instruction: shift left
            Memory[31] = 8'b0000_0000;
            Memory[30] = 8'b0101_0111;
            Memory[29] = 8'b1100_0110;
            Memory[28] = 8'b0000_1000;
            // Setting 32-bit instruction: shift right
            Memory[35] = 8'b0000_0000;
            Memory[34] = 8'b0110_1010;
            Memory[33] = 8'b1101_0010;
            Memory[32] = 8'b0111_1001;
            /// Setting 32-bit instruction: Campare
            Memory[39] = 8'b0000_0000;
            Memory[38] = 8'b0111_1010;
            Memory[37] = 8'b1101_0010;
            Memory[36] = 8'b0110_1010;
            Memory[43] = 8'b0000_0000;
            Memory[42] = 8'b0111_0111;
            Memory[41] = 8'b1101_0010;
            Memory[40] = 8'b0111_0010;
        end
endmodule
//IFU
The instruction fetch unit has clock and reset pins as input and 32-bit instruction code as output.
Internally the block has Instruction Memory, Program Counter(P.C) and an adder to increment counter by 4,
on every positive clock edge.
module IFU(
    input clock,reset,
reg [31:0] PC = 32'b0;  // 32-bit program counter is initialized to zero
    always @(posedge clock, posedge reset)
    begin
        if(reset == 1)  //If reset is one, clear the program counter
        PC <= 0;
        else
        PC <= PC+4;   // Increment program counter on positive clock edge
    end
    // Initializing the instruction memory block
    INST_MEM instr_mem(.PC(PC),.reset(reset),.Instruction_Code(Instruction_Code));
endmodule
///MUX
module Mux_2X1 (
    input mem_rd_select, // rd_mem_enable
    input wire [31:0] dataread_from_mem, regdata2,
    output reg [31:0] mux_out
always @(mem_rd_select or dataread_from_mem or regdata2) begin
    if (mem_rd_select == 1)
        mux_out <= dataread_from_mem ;
    else
        mux_out <= regdata2;
    end
endmodule
//DFlipFlop
module DFlipFlop(D,clock,Q);
input D; // Data input
input clock; // clock input
output reg Q; // output Q
always @(posedge clock)
begin
 Q <= D;
end
endmodule
///DATA path
module DATAPATH(
    input [4:0]Read_reg_add1,
    input [4:0]Read_reg_add2,
    input [4:0]Reg_write_add,
    input [3:0]Alu_control,
    input [11:0]Address,
    input Wr_reg_enable,Wr_mem_enable,Rd_mem_enable,
    input clock,
    input reset,
    output OUTPUT
    // Declaring internal wires that carry data
    wire zero_flag;
    wire [31:0]Dataread_from_mem;
    wire [31:0]read_data1;
    wire [31:0]read_data2;
    wire [31:0]Mux_out;
    wire [31:0]Alu_result;
    //wire [31:0]datawrite_to_reg;
    // Instantiating the register file
    REG_FILE reg_file_module(.reg_read_add1(Read_reg_add1),.reg_read_add2(Read_reg_add2),.reg_write_add(Reg_write_add),.datawrite_to_reg(Alu_result),.read_data1(read_data1),.read_data2(read_data2),.wr_reg_enable(Wr_reg_enable),.clock(clock),.reset(reset));
    // Instanting ALU
    ALU alu_module(.A(read_data1), .B(Mux_out), .alu_control(Alu_control), .alu_result(Alu_result), .zero_flag(zero_flag));
    //Mux
    Mux_2X1 mux(.mem_rd_select(Rd_mem_enable),.dataread_from_mem(Dataread_from_mem),.regdata2(read_data2),.mux_out(Mux_out));
    //Data Memory
    Data_Mem DM(.clock(clock),.rd_mem_enable(Rd_mem_enable),.wr_mem_enable(Wr_mem_enable),.address(Address),.datawrite_to_mem(Alu_result),.dataread_from_mem(Dataread_from_mem));
    // Dflipflop
    DFlipFlop DF (.D(zero_flag), .Q(OUTPUT),.clock(clock));
endmodule
A register file can read two registers and write in to one register.
The RISC V register file contains total of 32 registers each of size 32-bit.
Hence 5-bits are used to specify the register numbers that are to be read or written.
Register Read: Register file always outputs the contents of the register corresponding to read register numbers specified.
Reading a register is not dependent on any other signals.
Register Write: Register writes are controlled by a control signal RegWrite.
Additionally the register file has a clock signal.
The write should happen if RegWrite signal is made 1 and if there is positive edge of clock.
module REG_FILE(
    input [4:0] reg_read_add1,
    input [4:0] reg_read_add2,
    input [4:0] reg_write_add,
    input [31:0] datawrite_to_reg,
    output [31:0] read_data1,
    output [31:0] read_data2,
    input wr_reg_enable,
    input clock,
    input reset
    reg [31:0] reg_memory [31:0]; // 32 memory locations each 32 bits wide
    initial begin
        reg_memory[0] = 32'h00000000;
        reg_memory[1] = 32'hFFFFFFFF;
        reg_memory[2] = 32'h00000002;
        reg_memory[3] = 32'hFFFFFFFF;
        reg_memory[4] = 32'h00000004;
        reg_memory[5] = 32'h01010101;
        reg_memory[6] = 32'h00000006;
        reg_memory[7] = 32'h00000000;
        reg_memory[8] = 32'h10101010;
        reg_memory[9] = 32'h00000009;
        reg_memory[10] = 32'h0000000A;
        reg_memory[11] = 32'h0000000B;
        reg_memory[12] = 32'h0000000C;
        reg_memory[13] = 32'h0000000D;
        reg_memory[14] = 32'h0000000E;
        reg_memory[15] = 32'h0000000F;
        reg_memory[16] = 32'h00000010;
        reg_memory[17] = 32'h00000011;
        reg_memory[18] = 32'h00000012;
        reg_memory[19] = 32'h00000013;
        reg_memory[20] = 32'h00000014;
        reg_memory[21] = 32'h00000015;
        //reg_memory[22] = 32'h00000016;
        //reg_memory[23] = 32'h00000017;
        //reg_memory[24] = 32'h00000018;
        //reg_memory[25] = 32'h00000019;
        //reg_memory[26] = 32'h0000001A;
        //reg_memory[27] = 32'h0000001B;
        //reg_memory[28] = 32'h0000001C;
        //reg_memory[29] = 32'h0000001D;
        //reg_memory[30] = 32'h0000001E;
        reg_memory[31] = 32'hFFFFFFFF;
    end
    // The register file will always output the vaules corresponding to read register numbers
    // It is independent of any other signal
    assign read_data1 = reg_memory[reg_read_add1];
    assign read_data2 = reg_memory[reg_read_add2];
    // If clock edge is positive and regwrite is 1, we write data to specified register
    begin
        if (wr_reg_enable) begin
            reg_memory[reg_write_add] = datawrite_to_reg;
        end
    else
        reg_memory[reg_write_add] = 32'h00000000;
    end
endmodule
/////PROCESSOR
module PROCESSOR(
    input clock,
    input reset,
    output Output
    wire [31:0] instruction_Code;
    wire [3:0] ALu_control;
    wire WR_reg_enable;
    wire WR_mem_enable;
    wire RD_mem_enable;
    IFU IFU_module(.clock(clock), .reset(reset), .Instruction_Code(instruction_Code));
    CONTROL control_module(.opcode(instruction_Code[4:0]),.alu_control(ALu_control),.regwrite_control(WR_reg_enable),.memread_control(RD_mem_enable),.memwrite_control(WR_mem_enable));
    DATAPATH datapath_module(.Wr_mem_enable(WR_mem_enable),.Rd_mem_enable(RD_mem_enable),.Read_reg_add1(instruction_Code[9:5]),.Read_reg_add2(instruction_Code[14:10]),.Reg_write_add(instruction_Code[19:15]),.Address(instruction_Code[31:20]),.Alu_control(ALu_control),.Wr_reg_enable(WR_reg_enable), .clock(clock), .reset(reset), .OUTPUT(Output));
endmodule
Below is my Synthesis.tcl file for genus synthesis
set_attribute lib_search_path "/home/sameer23185/Desktop/VDF_PROJECT/lib"
set_attribute hdl_search_path "/home/sameer23185/Desktop/VDF_PROJECT"
set_attribute library "/home/sameer23185/Desktop/VDF_PROJECT/lib/90/fast.lib"
read_hdl Master.v
elaborate
read_sdc Min_area.sdc
set_attribute hdl_preserve_unused_register true
set_attribute delete_unloaded_seqs false
set_attribute optimize_constant_0_flops false
set_attribute optimize_constant_1_flops false
set_attribute optimize_constant_latches false
set_attribute optimize_constant_feedback_seqs false
#set_attribute prune_unsued_logic false
synthesize -to_mapped -effort medium
write_hdl > report/HDL_min_Netlist.v
write_sdc > report/constraints.sdc
write_script > report/synthesis.g
report_timing > report/synthesis_timing_report.rep
report_power > report/synthesis_power_report.rep
report_gates > report/synthesis_cell_report.rep
report_area > report/synthesis_area_report.rep
gui_show
WHEN I COMPARING MY GOLDEN.V WITH HDL_min_Netlist.v  during   conformal , I got  these  non-equivalent   point   for   every reg memory and for every data memory. I don't know what to do with these non-equivalent point. I've been stuck here for the past four days. Please help me in this and how can I remove this non- equivalent point , since I am new to this I really don't know what to do.
  • Fotios Nt
    Fotios Nt over 1 year ago
    There's a whole lot of issues that need fixing in your flow. You are for one using a very old synthesis approach that's not maintained for almost 10 years now (the synth -to_mapped command). Instead, if you just want a new-ish but very barebones synthesis script load up genus and run write_template command, and then fill in the blanks (libraries sdc etc). Flowtool is a much better approach, but it has a steeper learning curve
    Then, you need to run LEC in 2 steps:
    1) RTL to fv_map (fv_map is an intermediate netlist generated from syn_map, which is the upgraded version of synthesize -to_mapped) . This LEC dofile will get automatically generated for your when you run syn_map, and by default will be found in fv/<top level name>/rtl_to_fv_map.do
    2) fv_map to your final synthesis netlist. Use write_do_lec -golden fv_map (this is a reserved keyword, use it as is) -revised <your revised netlist here> to generate that dofile
    Conformal non-equivalences cannot be debugged via a simple screenshot unfortunately. You need to go to the mapping manager, open the diagnosis manager, and look at the GUI for clues. There is a conformal RAK as well that contains a lab that should get you familiar with that flow
