  2. Allegro X APD
  3. DFA check space of compont to BGA ball or BGA PAD in AP...
  • State Suggested Answer
  • Answers 1
  • Subscribers 67
  • Views 6600
DFA check space of compont to BGA ball or BGA PAD in APD
zpofrp
zpofrp over 1 year ago
There are mang components in BGA ball side of flipchip package.
Are there DFA check space of compont body or pin soldermask to BGA ball or BGA PAD or bga  soldermask in allegro APD?
I only find space of compont to compont in APD DFA.
  • John T
    0 John T over 1 year ago
    Hi zpofrp, yes APD can easily create check for bga pin to package. This is done via Manufacturing checks Design For Assembly > Spacing > Component Body to...
    This looks as shown in the image below:
    Step 1:Create the rule constraint set.
    Step 2: Assign the rule to each layer as desired.
    Error example shown for Component Body to "All pin pads" using a standard license. In higher grade licenses we get a more granular checking ability as per the image below:
  • zpofrp
    0 zpofrp over 1 year ago in reply to John T
    I try it, its OK in a new design. But i set it in a old design, it is wrong.
    There are many dielectrics above the top layer in the old design. There are many dielectrics below the bottom layer in the old design. This dielectrics are for substrate engineering.
    I don't know what caused it.
  • zpofrp
    0 zpofrp over 1 year ago in reply to zpofrp
    I guess the compont is be placed on dielectric, for example slod-bot,slod-top/
