  3. How to see placement reasons of cells? How to highlight...
  • Subscribers 92
  • Views 2039
How to see placement reasons of cells? How to highlight timing start/end points?
YYUE
YYUE over 1 year ago
I am working with innovus on a huge design. I found some cells are placed far away from both timing start points and timing end points. I suspect some other timing paths may be near-critical that results in this sub-optimal cell placement; or innovus has to place the cell far away due to congestion of placement or routing.
Is there a way to see why innovus places/moves the cell during place_opt_design or ccopt_design?
Also, is there a way to highlight all timing start points or timing end points that go through a cell? There may be thousands of timing paths through this cell. I tried using report_timing and timing debugger but it is very painful to click the highlight box and highlight the timing paths one by one.
Thank you for your help!
