  2. Functional Verification
  3. [Xcelium][xrun] Simulate with multiple builds
  • Subscribers 67
  • Views 4074
Minh Tran
Minh Tran over 1 year ago
I want to do a 2-step build->simulate as follow:
1. Make multiple builds using xrun -elaborate [other options]. The purpose is to create multiple builds with different compile-time macros (+define+MACROA +define+MACROB=ABC). Each build is located in a different directory.
2. Run simulation with xrun -r. This is where I need help. How do I specify which build to simulate? Also, I need the simulation directory (with log files, …) to be different than the build directory.
Has anyone been able to achieve this or similar solutions?
  • StephenH
    StephenH over 1 year ago
    If you simulate with the -xmlibdirname option, you can point xrun to the exact build directory. There is no requirement to simulate from the directory where you elaborated the snapshot.
