  2. Functional Verification
  3. xcelium - CSI: *F,INTERR: INTERNAL EXCEPTION
  • Subscribers 67
  • Views 3790
AB_1716112859938
AB_1716112859938 over 1 year ago
I just completed the setup of xcelium and I am trying to test a very simple vhdl file - I got " CSI: *F,INTERR: INTERNAL EXCEPTION" without any further explanation. Could someone point me to how to investigate this error further?
csi-xmelab - CSI: Command line:
xmelab
-f /home/cadadmin/test/xcelium.d/run.lnx86.23.03.d/xmelab.args
-ACCESS +r
-no_analogsolver
-MESSAGES
andgate
-XLMODE ./xcelium.d/run.lnx86.23.03.d
-RUNMODE
-CDSLIB ./xcelium.d/run.lnx86.23.03.d/cds.lib
-HDLVAR ./xcelium.d/run.lnx86.23.03.d/hdl.var
-WORK worklib
-IRUNHASTOP
-CHECK_VERSION TOOL: xrun 23.03-s001
-LOG_FD 4
csi-xmelab - CSI: *F,INTERR: INTERNAL EXCEPTION
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
TOOL: xmelab 23.03-s001
OPERATING SYSTEM: Linux 4.18.0-513.9.1.el8_9.x86_64 #1
Elaboration of package STD.STANDARD
csi-xmelab - CSI: Cadence Support Investigation, recording details
csi-xmelab - CSI: investigation complete took 0.000 secs, send this file to Cadence Support
  • StephenH
    StephenH over 1 year ago
    The fact this points to the STD.STANDARD library / package, makes me suspect that the Xcelium installation hasn't been completed correctly.
    If you haven't already resolved this problem, please login to https://support.cadence.com/ and file a support ticket (this forum isn't intended for detailed or time-critical technical support)
