  3. Innovus 'syntax error'. but works in Genus
  • Subscribers 94
  • Views 5179
AB_1717495972235
AB_1717495972235 over 1 year ago
Hi everyone,
I'm new to using Innovus and I'm encountering an issue while trying to perform the "init_design" command. My goal is to perform the place and route. Here are the commands I'm using:
set init_verilog ./test.v
set init_top_cell TEST
set init_pwr_net {VDD VDD_2 VDD_3}
set init_gnd_net {VSS VSSA}
set init_lef_file { /home/laumecha/uw_openroad_free45/pdk/Drexel-ECEC575/Encounter/NangateOpenCellLibrary/Back_End/lef/NangateOpenCellLibrary.lef}
set init_mmmc_file {./viewDefinition.tcl}
init_design
However, I receive the following error:
#% Begin Load netlist data ... (date=06/04 12:07:50, mem=1478.7M)
*** Begin netlist parsing (mem=1439.0M) ***
Created 0 new cells from 0 timing libraries.
Reading netlist ...
Backslashed names will retain backslash and a trailing blank character.
**ERROR: (IMPVL-209):   In Verilog file './test.v', check line 16 near the text # for the issue: 'syntax error'.  Update the text accordingly.
Type 'man IMPVL-209' for more detail.
Verilog file './test.v' has errors!  See above.
*** Memory Usage v#1 (Current mem = 1439.027M, initial mem = 634.098M) ***
#% End Load netlist data ... (date=06/04 12:07:50, total cpu=0:00:00.0, real=0:00:00.0, peak res=1478.7M, current mem=1478.7M)
**ERROR: (IMPVL-902):   Failed to read netlist ./test.v. See previous error messages for details.  Resolve the issues and reload the design.
However, the file works perfectly in Genus.
It seems there is a syntax error in my Verilog file at line 16, but I'm not sure how to resolve it. Any guidance or suggestions would be greatly appreciated.
Thanks in advance!
  • Dr Mamidi
    Dr Mamidi over 1 year ago
    I have checked with a simple counter program using , and it worked fine for me.
    Here is the innovus log reported as follows:
    Read 134 cells in library NangateOpenCellLibrary.
    Library reading multithread flow ended.
    *** End library_loading (cpu=0.05min, real=0.02min, mem=46.5M, fe_cpu=0.57min, fe_real=1.60min, fe_mem=1059.1M) ***
    #% Begin Load netlist data ... (date=06/06 23:35:42, mem=843.1M)
    *** Begin netlist parsing (mem=1059.1M) ***
    Created 134 new cells from 2 timing libraries.
    Reading netlist ...
    Reading verilog netlist 'counter_netlist.v'
    *** Memory Usage v#1 (Current mem = 1059.109M, initial mem = 476.031M) ***
    *** End netlist parsing (cpu=0:00:00.0, real=0:00:00.0, mem=1059.1M) ***
    #% End Load netlist data ... (date=06/06 23:35:42, total cpu=0:00:00.0, real=0:00:00.0, peak res=849.1M, current mem=849.1M)
    Set top cell to counter.
    Hooked 268 DB cells to tlib cells.
    Starting recursive module instantiation check.
    No recursion found.
    Building hierarchical netlist for Cell counter ...
    *** Netlist is unique.
    ** info: there are 269 modules.
    ** info: there are 23 stdCell insts.
    So, it seems the problem might be with your "test.v" source code. Please cross-check your code for any syntax errors, especially around line 16.
    hope it helps. All the best.
