  2. Logic Design
  3. removing cdn_loop_breakers from netlist
  • Subscribers 62
  • Views 5666
Ganga Vinod
Ganga Vinod over 1 year ago
I was trying to remove the cdn_loop_breaker cells from the netlist.
When I tried the below 2 things, it removing the cdn_loop_breaker cells but while connecting the cdn_loop_breaker cell input to its proper connection, its somehow misleading the connections
Things i tried:
1.  remove_cdn_loop_breaker -instances *cdn_loop_breaker*
then i just ran remove_cdn_loop_breaker  comand without the -instances switch
2. remove_cdn_loop_breaker
both of the above things are not providing the proper connections after removing the loop_breaker_cells
