  3. Tempus ECO initial setup summary not matching timing report...
  • Subscribers 92
  • Views 5279
Tempus ECO initial setup summary not matching timing report results
AB_1719623383408
AB_1719623383408 over 1 year ago
We are currently setting up the Tempus flow and have ran into some mismatched data regarding ECO and timing reports. I generated a timing report before running ECO and saw six total setup violations. When running opt_signoff -setup, the initial setup summary that was printed in the shell only showed one violation. I can see that violation from the initial setup summary in my pre-ECO timing report and it is not the worst path. Upon further investigation, I forced the tool to try to fix setup on one of the other five violations from the timing report using the opt_signoff_select_setup_endpoints attribute and the tool said that the endpoint had positive slack and would be ignored.
Has anyone experienced something like this before?
