  3. UPF 3.1 / Genus - Cannot find any instance for scope
  • Subscribers 92
  • Views 2571
eq79
eq79 over 1 year ago
Hi, I'm using genus (Version 21.14-s082_1) to synthesis a VHDL-design with multiple power-domains. After reading the power intent file and calling 'apply_power_intent',  I get the following warning:
Warning : Potential problem while applying power intent of 1801 file. [1801-99]
: Cannot find any instance for scope '/:CHIP_TOP'. Rest of commands in this scope will be skipped (set_scope:../../upf/CHIP_TOP.upf:2).
: Check the power intent. If the scenario is expected, this message can be ignored.
The fist two lines of CHIP_TOP.upf:
upf_version 3.1
set_scope :CHIP_TOP
I simulated the same  UPF and VHDL files with Xeclium and was able to verify all the IEEE1801/UPF aspects I need without any problems. I don't know, why genus is having a problem with the 'scope'.
In genus, after getting the warning, running 'set_db power_domain:CHIP_TOP/BLOCK_A/PD_CORE_D .library_domain PD0V5' returns the following error:
Error : <Start> word is not recognized. [TUI-182] [set_db]
: 'power_domain:CHIP_TOP/BLOCK/PD_CORE_D' is not a recognized object/attribute. Type 'help root:' to get a list of all supported objects and attributes.
: Check if the given <Start> word is a valid object_type, object or attribute.
Running 'commit_power_intent' gives me:
Started inserting low power cells...
Info : Command 'commit_power_intent' cannot proceed as there are no power domains present. [CPI-507]
: Design with no power domains is 'design:CHIP_TOP'.
Completed inserting low power cells (runtime 0.00).
I'm suspecting that the problem lies in 'set_scope' and VHDL. I never had such problems with Verilog. I tried every way to reference the hierarchy in the code and now I'm at my wit's end and I need your help \o/
How to set the scope with 'set_scope' in UPD 3.1 to the toplevel in VHDL, so that genus accepts it? Or is the problem caused by something else?
Best,
Iqbal
  • eq79
    Hi, I rewrote the top-level in Verilog, so now it's 'set_scope CHIP_TOP'. I still get the same warning as above and the rest of the file is ignored. So it's not a VHDL thing. I removed the line, 'set_scope', from the upf file and now it's working -.-
