  2. Functional Verification
  3. Collecting Coverage using Vmanager
  • Subscribers 67
  • Views 5277
MT202409027637
MT202409027637 over 1 year ago
I am running a regression in order to collect the coverage. However I have an issue. I am setting a signal to 0 when reset is de-asserted  then this signal takes a fixed value when the reset is asserted.
if(!rst_n)
init_val= 'b0;
else
init_val= 31'h34013FF7
the issue is that I got 0%  coverage for the init_value since we only have a rising edge and the signal is not toggling during the simulation. is there an option to collect coverage when there is a rising edge or a falling edge?
  • StephenH
    StephenH over 1 year ago
    Your question is somewhat ambiguous, because toggle coverage is automatically collected for rising and falling edges, and you haven't clarified exactly what you currently observer and what you would like to observe.
    You can configure coverage instrumentation using a coverage control file at elaboration time, have a look at the docs https://support.cadence.com/apex/techpubDocViewerPage?xmlName=iccugn.xml&title=Integrated%20Coverage%20User%20Guide%20--%20Table%20of%20Contents&hash=&c_version=24.03&path=iccugn/iccugn24.03/iccugnTOC.html in particular the section "Understanding Toggle Coverage".
    But to be honest, I would be inclined to simply exclude this signal from toggle coverage, as it doesn't appear to provide any value in terms of telling you what has been verified. Block coverage would already tell you if you've execute the if-true and if-else branches.
