  3. Tool to create *.lib and *.db files for designs made in...
  • Subscribers 92
  • Views 5220
Tool to create *.lib and *.db files for designs made in Innovus
sbfisher
sbfisher over 1 year ago
Hi all,
I have made a custom cell in Innovus that I will be instantiating into a bigger block, which I will also be using Innovus to do the Place & Route.
I understand that I can generate a *.lef file and a *.lib file using Innovus. However, I need to also create a *.db file (these format of files are often used in DC Compiler synthesis tool).
Is there a way to create the *.db file from Innovus? Or, is there a tool that I can use to create this *.db file?
Thank you for your time.
