  3. Import LEF file failed due to layermap
  • Subscribers 131
  • Views 4081
TzuYun Chang
TzuYun Chang over 1 year ago
I have a LEF file with simple definitions of pad design which uses M8, M9, and AP layers. However, I failed to import the design with CIW > Import > LEF... as I encountered "ERROR: (OALEFDEF-90019): Ignoring the line 30 in the layer map file ... as it contains a syntax error. Each entry in the layer map file must have two values, LEFLayerName and OALayerNumber separated by a blank space." All lines in the file report the same OALEFDEF-90019 error.
The tech.layermap file looks like this:
# techLayer       techPurpose     stream# dataType
ref drawing 0 0
DNW drawing 1 0
PW drawing 2 0
