  3. Change code in veriloga view from external program
  • Subscribers 131
  • Views 3834
mikewu999
mikewu999 over 1 year ago
For reasons too complicated to go into here, I need to generate the code for a veriloga view from a outside the normal Verilog-A editor. I would start with an "empty" veriloga view generated from the symbol in the normal way so I get the port order correct, then use external code to provide "guts" of the veriloga view by overwriting the generated code.
My understanding is that and code changes made external to the normal flow do not get picked up by Cadence - the Verilog-A code gets read at design time, not at netlist time. Would simply forcing a check and save of the veriloga view after the code is modified fix that problem? Or is there an easier way to incorporate externally generated Verilog-A code?
    Having updated the veriloga.va file within the cellView you can call the SKILL function vmsUpdateCellViews(?lib "libName" ?cell "cellName" ?view "veriloga" ?viewt "text.veriloga") to rebuild the OA database needed for netlisting.
