  3. Author and library name in sheet border
  • Subscribers 129
  • Views 4245
DomiHammerfall
DomiHammerfall over 1 year ago
Dear community
We would like to have more minimalistic and customized sheet borders for our schematics. I used this guide to create a starting point. Essentially, I made a copy of the US_8ths library and modified the Title symbol to look something like that:
Problem 1
The variable ilInst~>libName points to the library of the sheet border symbols, not to the library of the schematic. How do I need to modify this field in order to see the library name of the schematic where the border is instantiated?
Problem 2
The function CCSgetCreator() was taken from here. This solution does not seem to work with our management toll (we use VersIC); the function always returns nil as value. What is the simplest way to display the name of the user that created the schematic? A custom field that could be filled manually would also do the job for us; it doesn't need to be something that automatically fetches data from a database system.
Thanks for any input.
    For problem 1, change the label expression to ilInst~>cellView~>libName - this will then show the library name of the containing schematic.
    For problem 2, either find an appropriate function to retrieve this information from VersIC (you should speak to Perforce about this, since it's their tool), or if you're OK with entering it, add an NLPLabel (similar to the [@title] ) with something like [@author] (make sure the label type is set to NLPLabel). Then in the sheet symbol, use Edit->Properties->CellView and update the schSheetTitles property (if there is one). This is covered in the documentation (search for schSheetTitles) but it's an ILList property and the value for the Asheet in US_8ths is:
    ((("company" "string") ("dwg_no" "string") ("CAGE" "string")) (("rev" "string") ("title" "string") ("title1" "string")))
    The idea is that this is a list of properties to be set on the sheet. You can add a new entry to this (or remove those you don't want) to say:
    ((("company" "string")) (("author" "string") ("title" "string")))
    The first list is the global properties, and the second is the sheet-specific properties. It may not matter that much...
    Anyway, having done this, you can then use (when using the sheet) Edit->Sheet Title or Right Mouse->Edit Title over the sheet instance to update the values.
  • DomiHammerfall
    DomiHammerfall over 1 year ago in reply to Andrew Beckett
    Dear Andrew
    Thank you very much for you response. I can confirm that both solutions work as intended (for the second problem, I only checked the simpler solution with the NLPLabel though).
