  3. Verilog-A: Can I ignore WARNING (VACOMP-1047)
  • Subscribers 129
  • Views 3869
mikewu999
mikewu999 over 1 year ago
I need to include Verilog-A files which live outside the Cadence ecosystem (i.e., they are not in veriloga views but rather are just text files) into a veriloga view. These external modules are not compatible with OA (parametized port widths) so I can't put them into cellviews and hook them together using schematics.
Example: I have a cellview "test" which has a symbol and veriloga view. I have three "externaI" modules mod1 (inside an external file mod1.va),  mod2 (inside an external file mod2.va),  and mod3 (inside an external file mod3.va). I instantiate one instance of each module in "module test". The three modules have some parametized ports which are interconnected by parameterized signals p1 and p2. These two signals are strictly local to the module.
At the bottom of the module I use "`include mod1.va", "`mod2.va", etc.
When I check and save test->veriloga it checks all the included modules as well as the "test" module. However, I get a warning:
Warning from spectre during AHDL compile.
WARNING (VACOMP-1047): The Verilog-A file contains more than one module
definition. ADE can process only one module per Verilog-A file. Put
only one module in each Verilog-A file so that ADE can identify pin
names, directions, and hierarchy within each separate module.
Is this just a SUGGESTION that I can safely ignore, or are my included modules going to be ignored?
    I think this should be OK in this case. You are not expecting to use the sub-modules separately, nor configure them through the hierarchy editor. There is a way of handling parameterized port widths (I wrote an article on this) but it's not yet general purpose enough (on my to-do list) that it requires some customisation - probably not worth the bother in this case.
