  3. Xcelium/Simvision/xrun running very slow (waiting for SimVision...
  • Subscribers 129
  • Views 1339
Xcelium/Simvision/xrun running very slow (waiting for SimVision/Verisium Debug to connect...)
MT202407295352
MT202407295352 over 1 year ago
I would like to use the simulation software xrun/simvision that comes with XCELIUM. We are currently using classroom licenses and want to disable all ip addresses on the student pcs except the license server ip. We want to make sure that students cannot copy confidential data from the Cadence tools.
Problem:
When I launch the xrun simulation while all ip addresses are blocked, it starts but the performance is very slow. The GUI starts after 5 minutes and the simulation is ready after 10 minutes. The interesting thing is that when I enable all blocked ip addresses, everything works at a reasonable speed.
Terminal Output (execution without internet connection):
xrun -gui design.vhd
Is there a way to run the simulation tools without an Internet connection? Or can you give me the ip addresses that are used by the simulation tools so that I can enable only those specific ips?
Max
