  3. Transient Simulation waveform abnormal
  • Subscribers 131
  • Views 4061
SkkyLee
SkkyLee over 1 year ago
Hello Everybody
Recently, I want to design a high output Power Amplifier at 2.4GHz using TSMC 1P6M CMOS Bulk Process. I use its nmos_rf_25_6t transistor model to determine the approximate mosfet size
I use the most common Common-Source Differential Amplifier topology with neutralizing capacitor to improve its stability and power gain performance
Because I want to output large power, the size of mosfet is very large, the gate width is about 2mm, when I perform harmonic balance analysis, everything is alright, the OP1dB is about 28dBm (0.63Watt)
But When I perform Transient simulation, the magnitude of voltage and current waveform at the saturation point is too small, for voltgae, Vpeaking is about 50mV, for current, Ipeaking is about 5mA
I assume some reasons: the bsim4 model is not complete/ the virtuoso version is wrong (My virtuoso version is IC6.1.7-64b.500.21)/the spectre version is wrong (spectre version is 15.1.0 32bit)/the MMSIM version is wrong/Transient Simulation setting is wrong (the algorithm is select gear2only, but when I select other, like: trap, the results have no difference), the maxstep I set 5ps, minstep I set 2ps to improve simulation speed, I think this step is much smaller than the fundamental period (1/2.4e9≈416ps)
I have no idea how to solve this problem, please help me! Thank you very very much!
  • hayess
    hayess over 1 year ago
    Have you tried tweaking the BSIM4 model settings or maybe checking if there are updates for your Virtuoso or Spectre versions? Sometimes a small setting can make a big difference.
