  3. How to get maximum value of s11 Trace
  • Subscribers 129
  • Views 3698
NS202408066722
NS202408066722 over 1 year ago
Hello
i did a sp-Analysis and now i want to extract the maximum value of the s11 trace and the corresponding frequency.
I already tried ymax() in the calculator but i am suspecting it only works on transient Signals.
    Use mag() first before taking the ymax(). The issue is that s11 will be complex - and when plotted on a rectangular graph, it will plot the magnitude automatically - however, the ymax() function doesn't know that is what you want with a complex waveform, so you need to do an explicit mag() first (or db20 or whatever you want to do on the complex waveform).
  • NS202408066722
    NS202408066722 over 1 year ago in reply to Andrew Beckett
     it worked, thank you very much!
    Best Regards
    Niklas
