  3. error when generating snp files from a variable
  • Subscribers 131
  • Views 4321
TommasoF
TommasoF over 1 year ago
Hello everyone,
I have a testbench for generating s2p files from a SP simulation that was working until few months ago. Today I have reopened (w/o making changes that I am aware of) and I get the error as shown below:
first I show the testbench settings:
notice how the s2p generation is disabled: the field "file" is left blank
in the corner I defined some parameters, "filename" is the word that is suppose to generate the name for the s2p.
where the two variables are defined as follows
And now the output log:
spectre.out file gives the following error:
When clicking on the error message at "9", the input.scs file opens up and the line 9 gets highlighted in green
now, so far I understood that the problem seem to be related tom the "pathcds" variable, but I really don't understand what the error message here means, since I don't see any error in the input.scs file
by the way - if for instance I define the variable "filename" as shown below, then I get no errors:
thanks
Tommaso
  • TommasoF
    I am using this virtuoso version
  • Frank Wiedmann
    Frank Wiedmann over 1 year ago
    I think that the problem is that the quotes around the filename parameter are missing in the netlist. Spectre combines the lines ending with the backslash into a single very long line, that's why the message says "column 416".
  • TommasoF
    TommasoF over 1 year ago in reply to Frank Wiedmann
    thank you Frank, good hint, let me have a look
