  3. ddt VerilogA usage
  • Subscribers 129
  • Views 3416
ddt VerilogA usage
AndreaD
AndreaD over 1 year ago
reading Verilog®-A Language Reference I found this description of ddt function I don't understand:
Use the time derivative operator to calculate the time derivative of an argument.
ddt( input [ , abstol | nature ] )
input is a dynamic expression.
abstol is a constant specifying the absolute tolerance that applies to the output of the ddt operator. Set abstol at the largest signal level that you consider negligible.
nature is a nature from which the absolute tolerance is to be derived.
Can anyone explain how abstol and nature are defined? how using them? an example would be really appreciated.
Andrea
