  3. Creating Web/Thermal shape for paste mask
  • State Verified Answer
  • Replies 8
  • Views 3108
JS202408156358
JS202408156358 over 1 year ago
Any tips or SKIL files to help create a thermal shaped openings for paste masks for a donut shaped pin for mics or stand-offs like below?
  • avant
    0 avant over 1 year ago
    You could create four static shapes on the package geometry / paste top layer in the footprint.
    You could also create a shape symbol and add it to the pad stack.
  • JS202408156358
    0 JS202408156358 over 1 year ago in reply to avant
    That is the way I have been approaching it, but was looking to see if Cadence had a skill file that would take od, id, w and angle and create one. I could not find anything and so I created a python script that does the math and generates a pcb script that can be replayed in allegro. Works great, I provide the four parameters, run it, and it generates the script that I replay and create the shape as seen below.
  • excellon1
    0 excellon1 over 1 year ago in reply to JS202408156358
    Hi JS,
    Nice work !. Might I ask did you come up with a method to fill the shapes and what was the key method needed to create the shape geometry within the PCB Editor so as to get your wagon wheel type shape.
    Best Regards
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago
    Hi JS202408156358!
    You can refer this code.
    axlCmdRegister("create_thermal_shape" 'create_thermal_shape)
    (defun create_thermal_shape ()
    let((angle layer in_put)
    layer = "BOARD GEOMETRY/ASSEMBLY_NOTES"
    axlVisibleLayer(layer t)
    in_put = axlEnterString(?prompts list("Please enter 3 params:\n Ex: 4,100,25"))
    if(in_put != nil && length(parseString(in_put ",")) == 3 then
    point = axlEnterPoint(?prompts "" ?points nil ?gridSnap t)
    if(point != nil then
    p_in_put = parseString(in_put ",")
    id = atoi(car(p_in_put))
    ra = atof(cadr(p_in_put))
    w = atof(caddr(p_in_put))
    printf(" id: %d\n ra: %.2f\n w: %.2f\n" id, ra, w)
    d = axlMXYAdd( 0:ra point)
    r_path = axlMakeDynamicsPath(list(list(d d 0.0 point ra t) list(d d) ) )
    poly1 = car(axlPolyFromDB(r_path ?layer layer ?endCapType 'ROUND))
    poly_expand = car(axlPolyExpand(poly1 -w 'NONE))
    poly2 = car(axlPolyOperation(poly1 poly_expand 'ANDNOT))
    wheel = 360.0 / id
    angle = 0.0
    poly_list = nil
    tmp_point = axlMXYAdd( 0 : (ra + w) point)
    while(angle <= 360.0
    point_rotate = axlGeoRotatePt(angle tmp_point point)
    r_path2 = axlMakeDynamicsPath(list(list(point point_rotate w) ) )
    poly3 = car(axlPolyFromDB(r_path2 ?layer layer ?endCapType 'NONE ?line2poly t))
    poly_list = cons(poly3 poly_list)
    angle = angle + wheel
    poly_or = car(axlPolyOperation(car(poly_list) cdr(poly_list) 'OR))
    poly_or2 = axlPolyOperation( poly2 poly_or 'ANDNOT)
    foreach(poly poly_or2
    axlDBCreateShape(poly t layer nil)
    Regards.
    HoangKhoi.
    • Vote Up +2 Vote Down
  • excellon1
    0 excellon1 over 1 year ago in reply to Hoangkhoipcb
    Hi HoangKhoi,
    Thanks for sharing your skill routine. It works very well. I'm sure many will find it useful.
    Best Regards.
