  3. How to resolve the impedance issue using the OrCAD X Pr...
  • Views 4340
How to resolve the impedance issue using the OrCAD X Professional
RohitRohan
RohitRohan over 1 year ago
Dear Community,
I have created a PCB board and let's say I have found some parts of the PCB board where there are impedance issues, then how to resolve that impedance issue using the OrCAD X Professional.
Rohit Rohan
  • excellon1
    0 excellon1 over 1 year ago
    Hi Rohit.
    Can you be more specific. For example are you talking about the impedance seen at the pin of a device. Or do you mean the physical PCB Traces. If the symbols are
    for RF what is the expected frequency of operation ?.
    Best Regards.
  • RohitRohan
    0 RohitRohan over 1 year ago in reply to excellon1
    Hai excellon1
    Thanks for your reply.
    I am getting the impedance at the Vias and the Cline traces.
    Rohit Rohan
  • oldmouldy
    0 oldmouldy over 1 year ago in reply to RohitRohan
    You haven't mentioned any design details but, quite likely, you have Thru Vias and the CLines won't have a reference plane where the Vias clear all Shapes and the CLines make a connection. As a result, the impedance, and calculation, will "spike". You can mitigate against this to some degree with BB Vias which won't cause a Shape clearance on all layers and will provide a reference plane.
