  3. Allegro PCB Router quit unexpectedly with an exit code of...
  • State Verified Answer
  • Subscribers 162
  • Views 1720
Allegro PCB Router quit unexpectedly with an exit code of -1073741701. Also, nothing is logged in log file.
MG202411074016
MG202411074016 over 1 year ago
Has anyone experienced the same situation?
  • vidhyaparameswari
    0 vidhyaparameswari over 1 year ago
    Could you please walk me through the steps you took leading up to the error, so I can replicate and troubleshoot the issue at my end?
  • MG202411074016
    0 MG202411074016 over 1 year ago in reply to vidhyaparameswari
    In Allegro X Designer 23.1(S007), I did following and got the error above. The error told me to go to the log file, which is empty. (I have checked that log file is working by doing another action such as Auto bundle)
  • vidhyaparameswari
    +1 vidhyaparameswari over 1 year ago in reply to MG202411074016
    A similar issue was previously reported by another user, and our investigation revealed that it typically occurs on systems that are missing the Microsoft Visual C++ 2012 Redistributable (x86) package. To resolve this issue, we recommend installing this package. Please try installing it and let us know if this resolves the problem. We appreciate your update on the outcome, as it will help us to further assist you if needed.
