  3. To add Assura Physical Layout Verification tool to Virt...
  • Subscribers 131
  • Views 18624
To add Assura Physical Layout Verification tool to Virtuso
archive over 19 years ago
I am a graduate student at University of Arizona. We use the TSMC 0.25 micron CMOS PDK as the start data base for my school project. The TSMC PDK accompany with the Assura layout verification (e.g., DRC, EXT, LVS etc.), but the Virtuso layout tool does not have the Assura radio button on the display panel. How can we add the Assura radio button in Virtuso, so we can use the Assura deck? Thanks for your help, D. Nguyen
Originally posted in cdnusers.org by dcnguyen
    You need to have Assura installed (e..g ASSURA316) in its own hierarchy, and then have the ASSURAHOME UNIX environment variable set and pointing to the installation root of the Assura installation.
    If you do that, then the Assura menus will appear in the layout editor.
    Originally posted in cdnusers.org by adbeckett
    archive over 18 years ago
    To where should Assura environment variable be set?
    i.e. should it be like that for example? :
    export ASSURAHOME=/usr/local/ASSURA314
    Thanks in advance,
    Originally posted in cdnusers.org by ahmad_abdulghany
    Thanks in advance,
    Thanks in advance,
