  2. Mixed-Signal Design
  3. Defining a string parameter in a systemverilog model as...
  • Subscribers 63
  • Views 21129
Defining a string parameter in a systemverilog model as a design variable
Soner
Soner over 12 years ago
Hi, I have a systemverilog module with a string parameter:
parameter string filename = "default_name";
When I instantiate this module and edit its object properties, I see the filename property. Whatever I write into this field is passed as a string to the module. Is it possible to define a design variable (which value I can control in ADE) and pass this design variable to this field?
The motivation is to be able to provide a unique filename in a parametric analysis. Otherwise, the file will be overwritten for each simulation.
    I think so - although I've not tested this. You'd have to ensure that the parameter is defined in the CDF as parseAsCEL=yes though. If that doesn't work, please contact customer support (I'm assuming AMS is the simulator).
    KInd Regards,
  • Soner
    Here is a workaround:
    1) Ensure that the parameter is defined in the CDF as parseAsCEL=yes
    2) Edit object properties of the instance, type pPar("myVariable")
    myVariable shows up as a design variable in ADE XL. Is it possible to make step #1 above automatic, just like parameters of type real?
    Soner Yaldiz
