  3. Virtuoso Video Diary: Bridging Virtuoso and Mixed-Signal…
Vani V
Vani V
custom/analog
Mixed-Signal
Virtuosity
Virtuoso Video Diary: Bridging Virtuoso and Mixed-Signal Simulation Tools Using CLIPS
25 May 2018 • 2 minute read
 Do you often face a problem while switching the digital representation of an IP to its corresponding mixed-signal representation to verify your designs? How easy do you think your life would be if you could bring the config views into the mixed-signal and command-line setup? And wouldn’t it be convenient if the netlists and configurations created in this new setup are supported by Spectre® AMS Designer?
You would be happy to know that Cadence has come up with Command-Line IP Selector (CLIPS) support that acts as a bridge between Virtuoso—a UI-based, analog, and mixed-signal design environment—and other command-line, digital, and mixed-signal simulation tools and flows that use a text-based setup. You can use CLIPS to import an AMS IP into an existing digital-centric verification setup.
CLIPS reads the mixed-signal command files, identifies the required AMS IP modules, uses Virtuoso ADE setup files to netlist the required modules, and pulls the AMS IP out of the Virtuoso environment. All the necessary files are extracted and packaged, as required for a mixed-signal SoC command-line verification run. For this, it provides both GUI-based and command-line use models, which are flexible and fit into the existing design flow methodology. The CLIPS setup can be saved and rerun as a batch process.
To know more about this feature, view the What is Command-Line IP Selector? How to use it? video available on Cadence Online Support. Click the video link now or visit Cadence Online Support and search for this video under Video Library.
  • User Guide
    • Command-Line IP Selector (CLIPS) User Guide
  • Rapid Adoption Kit
    • Command-Line IP Selector (CLIPS) RAK
About Virtuoso Video Diary
Virtuoso Video Diary is an online journal that relays information about Virtuoso videos that are available in the Cadence Online Support Video Library. Hundreds of interesting videos on a wide variety of new and exciting Virtuoso features have already been created. Virtuoso Video Diary brings you direct links to these videos and other related material, on regular basis. Click Subscribe to visit the Subscriptions box at the top of the page in which you can submit your e-mail address to receive notifications about our latest Virtuoso Video Diary posts.
Vani Verma
