  3. Virtuoso Video Dairy : Direct Measurements Assistant in…
Chandrika Durbha
Chandrika Durbha
ViVa-XL
Analog Design Environment
ViVA
Virtuoso Video Dairy : Direct Measurements Assistant in Virtuoso Visualization and Analysis XL
18 Sep 2020 • 3 minute read
Ever had to use long expressions just to create simple measurements for plots and waveforms or use markers to measure amplitude, rise, and fall times? That too when these measurements might not even stay in place?
 If yes, then read on to find out how you can simplify these tasks.
From IC6.1.8 ISR13 and ICADVM18.1 ISR13  releases, we have introduced the new Direct Measurements assistant in  Virtuoso Visualization and Analysis XL. The focus of the Direct Measurements assistant is to make the most commonly used measurements such as rise time, fall time, or delay between two transient signals available at a click of a button. The markers and labels are annotated automatically on the selected plots. This simplifies the process of creating, annotating, and updating measurements without the need to write lengthy expressions that were traditionally created through the Calculator tool in  Virtuoso Visualization and Analysis XL.
Direct Measurements assistant can be invoked from Virtuoso Visualization and Analysis XL,  Window > Assistants > Direct Measurements menu.
Direct Measurements assistant has three tabs Amplitude, Time, and Frequency.
Amplitude and Time Measurements
When running transient simulations, we usually want to look at the rise/fall times or duty cycle of the outputs. Let's look at a short video to see how the Direct Measurements assistant can be used to create annotations for these measurements,
Curious to know more? Download the VIVA-XL Direct Measurements Assistant Rapid Adoption Kit (RAK) from the Cadence Support portal. This RAK gives a detailed explanation of how to use the assistant.
Similarly, on the Freq tab, you can perform Frequency(ac) Measurements for stability – Gain margin, Phase margin, and Bandwidth can be annotated from the Freq tab.
  Do check out the VIVA-XL Direct Measurement Assistant video on the Cadence Support portal.
 Product Manuals
Virtuoso ADE Explorer User Guide
Virtuoso Visualization and Analysis XL User Guide
 Video
 Rapid Adoption Kit
Happy reading!
Chandrika Durbha
About Virtuoso Video Diary
Virtuoso Video Diary is an online journal that relays information about Virtuoso videos that are available in the video library on the Cadence Support portal. Hundreds of interesting videos on a wide variety of new and exciting Virtuoso features have already been created. Virtuoso Video Diary brings you direct links to these videos and other related material, on a regular basis. To receive notifications about new blogs in this series, click Subscribe and submit your email ID in the Subscriptions box.
