  3. Spectre Tech Tips: Introducing Spectre FMC Analysis
Jianhe Guo
Jianhe Guo
Spectre Circuit Simulator
Monte Carlo analysis
Spectre Fast Monte Carlo
Virtuoso ADE Assembler
ADE Assembler
31 Aug 2023 • 3 minute read
 As the process feature sizes have scaled down, the impact of device mismatch on circuit performance has increased and now, even more Monte Carlo simulations are required to analyze the impact of this mismatch on performance metrics. With standard Monte Carlo algorithms, it is not feasible (high cost) to complete even one million Monte Carlo simulations needed in memory design to determine 4σ yield numbers. It is obvious that more than one billion simulations would be required for high-sigma yield analysis.
Spectre FMC Analysis has been developed with an advanced algorithm to speed up the high-sigma simulation with two capabilities, FMC worst sample prediction and FMC yield estimation. This blog describes the command-line options to use these capabilities of Spectre FMC analysis.
FMC Worst Sample Prediction
This new feature allows you to extract useful statistical information without running the full set of Monte Carlo samples, especially for a high-sigma analysis. It simulates the worst samples of a measurement only in the tail of distribution based on the machine learning sample reordering method. Building a model with job distribution can further speed up the performance, as shown below.
 Spectre FMC analysis flow
Spectre FMC worst sample prediction is supported in both Virtuoso ADE Product Suite and Spectre command line.
To perform the worst sampling simulation, you need to specify any two of these parameters: numruns, fmcsigma and fmcnumtailsamples.
mc1 montecarlo numruns=20000 firstrun=1 seed=12345 \
   variations=all donominal=no savefamilyplots=no \
    fmcmethod=worstsample fmcsigma=3 {
       tran tran step=1p stop=2n
Then, specify the selected measurements to be identified for the worst sample in the statistics target goal block.
 statistics {
  target {
     goal  <measurement_name>  min=<value>
     goal  <measurement_name>  max=<value>
     goal  <measurement_name>  min=<value> max =<value>
FMC Yield Estimation
Spectre FMC yield estimation provides a fast answer for quick sigma, failure rate, and confidence intervals when the simulation budget is limited. It determines the yield based on the boundaries of a measurement goal with a fixed cost of simulations.
mc1 montecarlo numruns=1e+6 fmcmethod=yieldest  \
fmcbudget=3000 fmcconfidence=0.95 {
    tran tran step=1p stop=tran_time autostop=yes
To improve performance, you can use distributed mode for both FMC worst sample prediction and FMC yield estimation analyses. Use one of the available options, fork, lsf, or sge, to launch child processes. In addition, use the command-line option +mp=<number_of_processes> to specify the number of child processes to be launched.
 %bsub –R "(OSNAME==Linux)" "spectre +aps -mt +mp=50 input.scs –outdir fullpath/out_mp/"
 To run all the distributed jobs on the same host, specify +mplauncher=ksh in addition to the above command.
  • Blog: Early, Accurate, and Faster Exploration and Debug of Worst-Case Design Failures with ML-Based Spectre FMC Analysis
  • Spectre Classic Simulator, Spectre APS, Spectre X, Spectre XPS, Spectre FMC Analysis, and Legato Reliability Solution User Guide
You may also contact your Cadence Customer Support for guidance.
Jianhe Guo
About Spectre Tech Tips
Spectre Tech Tips is a blog series aimed at exploring the capabilities and potential of Spectre®. In addition to providing insight into the useful features and enhancements in Spectre, this series broadcasts the voice of different bloggers and experts, who share their knowledge and experience on all things related to Spectre. Enter your email address in the Subscriptions box and click SUBSCRIBE NOW to receive notifications about our latest Spectre Tech Tips posts.
