  3. Knowledge Booster Training Bytes – Interactive Short Locator…
Sarita Sharma
Sarita Sharma
Cadence Digital Badges
Cadence Blended Training
Physical Verification System (PVS)
Cadence training
training bytes
Cadence certified
Virtuoso Video Diary
Cadence Education Services
PVS
ISL
Knowledge Booster Training Bytes – Interactive Short Locator (ISL) in the PVS LVS Debug Environment
20 May 2022 • 4 minute read
In this Knowledge Booster blog, we talk about Interactive Short Locator (ISL) and explore how to debug shorts in the LVS debug environment using ISL. We also introduce you to the videos and training materials that can help you understand and use this feature.
What are Shorts?
Shorts happen when two or more nets in the netlist are connected together incorrectly. In the LVS Debug Environment window, it is recommended to start debugging errors from the Shorts tab because shorts significantly affect results reported in other tabs like Extraction and Comparison.
Interactive Short Locator (ISL) is used by PVS LVS to debug shorts in the LVS or ERC Error Browsers. Check out the An Introduction to Interactive Short Locator (ISL) video.
 An Introduction to Interactive Short Locator (ISL) used in the PVS LVS Debugging Environment.
How to Debug Shorts using ISL?
ISL employs the One-pass Short Isolation technique to display the paths that consist of shapes from the connected layers between the shorted labels.
It supports interactive navigation of the shapes along each shorts path found. ISL interactively places additional labels to reduce the path results. Interactive analysis of suspicious shape for short, and multithreading to reduce the runtime for shorts analysis, are other features of ISL.
Check out the How to Debug Shorts with Interactive Short Locator (ISL)? video.
 Debugging shorts with Interactive Short Locator using PVS LVS Debug Environment.
For lab instructions and a downloadable design, enroll for the online training course below:
Physical Verification System v21.1 (Online)
This course can also be booked as Blended Training. Contact your local training department for further information.
 On completion of the course, you are Cadence Certified and get a Digital Badge:
You can also share your knowledge on social media channels.
Note: Some of the links are accessible only to Cadence customers who have a valid login ID for the Cadence Learning and Support Portal.
Information and FAQs
To find information on creating an account on the Cadence Learning and Support portal, click here.
Related Resources
Training Bytes (Videos) Training Bytes (Videos)
PVS Introduction (Video)
PVS DRC (Video)
PVS LVS (Video)
Interactive Short Locator (ISL) (Video)
Pegasus Interactive Short Locator v20.2 (Channel Video)
Blogs Blogs
Come Join Us and Learn from the Cadence Training Offerings
Virtuoso Video Diary: Knowledge Booster Training Bytes – Part 3
Virtuoso Video Diary: Knowledge Booster Training Bytes - Part 7: The Virtuoso ADE Product Suite
Virtuoso Video Diary: Knowledge Booster Training Bytes - Part 6
Virtuoso Video Diary: Knowledge Booster Training Bytes – Part 8: Mixed-Signal Modeling Aspects of Verilog-AMS
Virtuoso Video Diary: Knowledge Booster Training Bytes – Part 12 - Using Quview and Connectivity Checker in Quantus
Virtuosity: Learn the Right Steps—Design 5G Your Way with Cadence Training
Take a Cadence Masterclass and Get a Badge
Do you want to Flaunt your Expertise? Grab the Digital Badge Today!
Online Course Online Course
Knowledge Booster Training Bytes is an online journal that relays information about Cadence Training videos, online courses, and upcoming webinars that are available in the Learning section of the Cadence Learning and Support portal. This blog category brings you direct links to these videos, courses, and other related material, on a regular basis.
Sarita Sharma
