  3. Knowledge Booster Training Bytes: Simplifying Shapes in…
Pratul Nijhawan
Pratul Nijhawan
blended
blended training
Cadence blogs
Virtuoso 3D Viewer
learning
EMX Models
training
Electromagnetic analysis
Cadence training
digital badges
training bytes
Cadence certified
Virtuoso Video Diary
online training
EMX Solver
Custom IC
3D Mesh
Knowledge Booster Training Bytes: Simplifying Shapes in the Virtuoso EM Solver
11 Feb 2025 • 4 minute read
In this Knowledge Booster blog, let us discuss an important feature of the Virtuoso electromagnetic (EM) solver integration for performing EM simulations with the EMX Solver (in Electromagnetic Solver Assistant): Shape Simplification. By simplifying the shapes of EM models, the number of unknowns is reduced, simplifying the overall model. This leads to faster EM simulations of the IC structures.
 In the Electromagnetic Solver Assistant, you have the shape simplification options to:
  • Merge and stripe the shapes of a coarser grid
  • Remove fill shapes
The Shape Simplification videos discussed in this blog are part of a four-day training course on the EM Analysis of ICs in the Virtuoso EM Solver integration (using the EMX Solver) are as follows.
  1. Video 1: In this video, various options available in the GUI for Shape Simplification, i.e., the Simplify Layout for EM Simulation Form in the Electromagnetic Solver Assistant are listed. These include the options for merging and striping of the shapes. Also, the options to remove fill shapes are listed.
  2. Video 2: This video describes configuring the initial settings for creating a model on which the shape simplification is applied. These include invoking the software (Virtuoso Layout Suite EXL) and creating and setting up the model.
  3. Video 3: Next, you learn to perform the merging and striping of shapes using the Simplify Layout for EM Simulation Form. The Merge Shapes option specifies the rules for merging shapes if they are within a given distance. The Stripe Shapes option converts a fine mesh into a coarse mesh.
  4. Video 4: This video describes how to protect the stripped-off shapes, i.e., to avoid useful shapes from getting simplified in an instance.
  5. Video 5: You are now introduced to removing the fill shapes, i.e., the floating metal fill shapes.
  6. Video 6: The fill shape removal using the EMX fill size Option (available under the Advanced EMX settings) is performed in this video.
  7. Video 7: The fill shape removal using the Skip all shapes on Lpp Option in the Simplify Layout for EM Simulation Form is performed in this video. Using this option allows you to eliminate unwanted metal fills.
  8. Video 8: The fill shape removal using the Remove dangling shapes Option in the Simplify Layout for EM Simulation Form is performed in this video. This option is applied on the specified metal fills and removes the shapes with no connectivity.
  9. Video 9: The fill shape removal using the Remaster instances Option in the Simplify Layout for EM Simulation Form is performed in this video. This option is used to remaster the complex instance with an equivalent simpler cell.
Want to Learn More?
  • For lab instructions and a downloadable design, enroll in the online training course
  • This course includes slides, audio instruction, and downloadable lab exercises in line with the lecture content
  • Training is also available as "blended" or "live" class
Note: Some of the above links are accessible only to Cadence customers who have a valid login ID for the Cadence Learning and Support Portal.
  • On the Cadence Support portal, select Register Now and provide the requested information on the registration page
  • You will need an email address and host ID in order to sign up
  • If you need help with registration, contact support@cadence.com
If you have questions about courses, schedules, online, public or live onsite training, reach out to us at Cadence Training.
 Blogs
Training Insights: EM Analysis of ICs Using EMX Solver in Virtuoso RF Solution
Come Join Us and Learn from the Cadence Training Offerings
It’s the Digital Era; Why Not Showcase Your Brand Through a Digital Badge!
The Year That Was: Knowledge Booster Training Bytes — Highlights from 2023
Knowledge Booster Training Bytes – Find and Enroll in a Cadence Online Training Course
Virtuoso Meets Maxwell: Viewing Your Mesh in EMX Planar 3D Solver
Virtuoso Meets Maxwell: Defining Ports in EMX Planar 3D Solver
Virtuoso Meets Maxwell: Playing with Ports During Electromagnetic Simulation
Virtuoso Meets Maxwell: Analyzing EMX Current Density in the Virtuoso 3D Viewer
 Online Courses
Electromagnetic Simulations Using the EMX Solver
5G mmWave Handset System Design – S1: Simulation and Verification of the RFIC (Transceiver)
Datasheets
(Other than those for courses)
Virtuoso Heterogeneous Integration
Product Manuals
Virtuoso Electromagnetic Solver Assistant User Guide: Product Version IC23.1
Virtuoso RF Solution Guide: Product Version IC23.1
EMX User Manual: Product Version 2023.2
GDSview User Manual: Product Version 2023.2
Rapid Adaption Kits (RAKs)
IC23.1: Virtuoso RF Solution: IC Layout Electromagnetic Simulation (Using EMX)
Virtuoso RF Solution: LVS-Based IC Electromagnetic Simulation
