  3. Spectre Tech Tips: Handling Differential Matching Circuits…
timlow
timlow
Circuit simulation
Spectre Circuit Simulator
Spectre X Simulator
Spectre Tech Tips: Handling Differential Matching Circuits in Spectre X
24 Feb 2023 • 2 minute read
 Differential matching circuits such as comparators require special handling of RC reduction for accuracy. By design, the differential pair of the comparator is closely matched such that any form of imbalance due to RC mismatch will lead to large differences. Thus, for any given differential pair, even a conservative setting can be problematic. The RC reduction applied on the “left” and “right” may vary based upon the predefined set tolerances. Therefore, it is always recommended that no RC reduction is performed on these types of circuits.
Small error % can lead to large inaccuracy
The efficiency of a comparator can be determined by its input offset voltage or the difference represented by a voltage source applied in series with one input of an ideal comparator. The differences in the input stage is the result of transistor imbalance and RC mismatch. Consequently, the output doesn't toggle when VIN+ = VIN-, as in the case of an ideal comparator, but the threshold level is shifted by the input offset value VIO as shown in Figure 1.
Figure 1: VIO is the input offset value
Preserve all nets that contribute to VIO
Spectre X by default detects postlayout content and enables RC reduction. This RC reduction may cause accuracy problems when applied to a comparator or similar differential design.
Nevertheless, Spectre X enables the user to customize RC reduction locally to a given net or block. This approach can be used to locally disable the reduction for all nets that contribute to VIO in the comparator.
Syntax:
opt1 options postlpreset=off +postlnets=[instance_of_comparator.*]
  • Introducing Spectre X
About Spectre Tech Tips
Spectre Tech Tips is a blog series aimed at exploring the capabilities and potential of Spectre® circuit simulator. In addition to providing insight into the useful features and enhancements in Spectre, this series broadcasts the voice of different bloggers and experts, who share their knowledge and experience on all things related to Spectre. Select SUBSCRIBE to receive notifications about our latest blog posts.
Timothy Low
