  3. Start Your Engines: Use Tcl to Save Signals More Efficiently…
Qingyu Lin
Qingyu Lin
save statement
AMS
AMS Designer
AMSD
Start Your Engines
Spectre AMS Designer
Mixed-Signal
probe
xcelium
Start Your Engines: Use Tcl to Save Signals More Efficiently in AMS Simulations
12 Sep 2023 • 3 minute read
Cadence Spectre AMS Designer is a high-performance mixed-signal simulation system. The ability to use multiple engines and drive from a variety of platforms enables you to "rev up" your mixed-signal design verification and take the checkered flag in the race to the market. The Start Your Engines! blog series will provide you with tips and insights to help you tune your simulation performance and accelerate down the road to productivity.
Saving signal waveforms during a simulation is one of the basic ways to check the simulation results. However, with large SoC designs, it’s not always practical to save all signals during simulation, and the simulation performance might also be impacted by the number of signals being saved. Therefore, a crucial part of the simulation setup is to specify the expected and essential signals to save.
Here are some examples of using TCL commands to save signals more efficiently:
  • Saving a single signal
Save the voltage of net3 in the hierarchy i1.i2.
probe -create top.i1.i2.net3
Save the current through port portA in the hierarchy i1.i2.
probe -create -flow top.i1.i2.portA
  • Saving multiple signals in an instance
Save the voltages of all ports and nets in instance i2 in hierarchy i1.
probe -create -noaicms top.i1.i2
Save the currents of all ports of instance i2 in the hierarchy i1.
probe -create -noaicms -flow -ports top.i1.i2
  • Saving selected signals in an instance
Using the -depth option, save the voltages of all ports and nets in instance i1, one level down the hierarchy.
probe -create -noaicms -depth 2 top.i1
Using the -ports option, save all currents through the ports of instance i1, one level down the hierarchy.
probe -create -noaicms -depth 2 -flow -ports top.i1
  • Saving selected signals in a module with multiple instances (applicable for analog scope in Verilog-AMS format)
Using with find command, save the voltages of all ports with the suffix out in the scope i1, one level down the hierarchy.
probe -create -noaicms [find -rec 1 -scope top.i1 -ports *out]
For more advanced usage, save the voltages of all ports with the suffix out that exist in instances whose names begin with i, in the current scope, one level down the hierarchy.
set inst_scope [find -instances -rec 1 -absolute -newline i*]
foreach {inst} $inst_scope { catch {probe -create -noaicms [find -scope $inst -ports *out]}}
As shown in the later examples, by combining probe and find commands, you will be able to precisely select the signals you need to save so that there is no redundant data in your waveform database and minimal impact on simulation performance.
Product
Manuals
Xcelium Simulator Tcl Command Reference
Spectre AMS Designer and Xcelium Mixed-Signal User Guide
Troubleshooting
Information
About Start Your Engines
The Start Your Engines series brings you blog posts from several analog/mixed-signal subject matter experts on a variety of topics, such as introduction to the new features in AMS Designer, tips for enhanced working with existing features, and much more. To receive notifications about new blogs in this series, click Subscribe and submit your email ID in the Subscriptions box.
