  3. Virtuoso Meets Maxwell: Thinking Outside the Chip--Advantages…
danbaldwin
danbaldwin
IC Packaging
Virtuoso RF Solution
Spectre
mixed signal
Virtuoso Meets Maxwell: Thinking Outside the Chip--Advantages of Interoperability Between Best-In-Class IC and IC Packaging Design and Verification Tools
7 Sep 2020 • 3 minute read
Many of today’s analog, RF, and mixed-signal designs require the integration of multiple ICs across varying substrate technologies to achieve required performance goals. The integration of heterogeneous devices allows designers to achieve results that can’t easily be duplicated using a monolithic IC (SoC) design approach. At the same time, heterogeneous integration introduces a whole new set of challenges for today’s designers.
System in package (SiP) is one of the most common methods of integrating mixed technologies into a single design. This approach requires seamless integration between the IC and package substrate design teams and an integrated tool flow. The Virtuoso MultiTech Framework addresses these challenges with a novel, integrated cross-platform solution that streamlines and automates the design of a package/module featuring off-chip devices and multiple ICs based on differing process design kits (PDKs).
Cadence® Virtuoso® MultiTech Framework links best-in-class IC and IC packaging technologies—the Virtuoso custom IC and Allegro® IC package design capabilities—creating a holistic methodology that automates and streamlines the design and verification flow for multi-die heterogeneous systems.
Cadence® Virtuoso® MultiTech Framework unifies the strengths of the Virtuoso Schematic Editor, Virtuoso ADE Assembler, and SiP Layout Option for IC and IC package/system-level capture, design, implementation, analysis, and verification. In addition, the Virtuoso MultiTech Framework provides an automated interface with Cadence® electromagnetic solvers.
Design engineers using the Virtuoso MultiTech Framework capabilities are empowered with capturing the system-level layout interconnect for any number of ICs (chiplets) along with other components comprised in a typical system. This evolutionary approach streamlines the validation of the constructed connectivity of the hierarchical system comprised of ICs, IC packages, and boards. Within a familiar environment capable of pre- and post-layout simulation along with in design layout versus schematic (LVS) check.
The Virtuoso MultiTech Framework utilizes a familiar use model within Virtuoso Schematic Editor to transfer the logic description to SiP Layout Option for physical implementation. The entire flow is automated from library creation, technology file creation and elimination of the highly manual and error-prone process of integrating system-level layout connectivity and parasitic model back-annotation to the golden schematic.
See the related Rapid Adoption Kit.
About Virtuoso Meets Maxwell
Click Subscribe to submit your email address for receiving notifications about our latest Virtuoso Meets Maxwell posts.
  • Virtuoso RF Solution
  • Virtuoso MultiTech Framework Guide
  • Virtuoso RF Solution Guide
Dan Baldwin
