  3. Virtuoso Studio: Plotting Templates-Compare, Focus and Analyze…
Udit Rajput
Udit Rajput
Corners
ViVa-XL
Virtuoso Studio
ADE Explorer
plotting
ViVA
ADE Artist
plotting templates
ADE Assembler
Virtuoso Studio: Plotting Templates-Compare, Focus and Analyze Like Never Before
20 Jan 2026 • 3 minute read
If you’ve ever spent hours customizing plots only to repeat the same steps for every new run, you know the struggle. Fortunately, we solved that challenge long ago with Plotting Templates—a powerful feature designed to save time and effort by letting you reuse your favorite plot configurations across runs and maestro views. But until recently, it had one limitation: Plotting templates worked only in New Window or Replace mode. That meant comparing results from different runs in a single graph window was…well, not so simple, but not anymore!
Plotting Templates in Append Mode: Compare Results without Juggling between Graph Windows
With the latest enhancements we made in IC25.1 ISR3, plotting templates now support Append Mode. This is a game-changer. You can reuse the same template and append results from multiple histories into a single graph window. No more juggling multiple windows or manually aligning plots—just seamless comparison across different simulation runs.
Why It Matters?
  • Compare different simulation runs in a single graph window
  • Eliminate clutter from multiple windows
  • Save time and improve clarity
Plot Filtered Corners: Focus on What Matters Most
If you’re working with hundreds of corners, analyzing everything at once can feel overwhelming.
Starting from IC25.1 ISR3, you can use the Filter Corners option to selectively view the results in the Results tab for the corners that matter most. Combine this with Plot Filtered Corners option to apply your plotting template only to the corners currently visible in the Results tab.
How?
  • Use the Filter Corners option to filter the corners of your interest.
  • Select a plotting template.
  • Click Plot Filtered Corners.
Why These Updates Matter Together
These enhancements make waveform analysis more flexible, efficient, and intuitive. Whether you’re comparing multiple simulation runs or drilling down into specific corners, you now have the tools to do it all—without wasting time or losing clarity.
  Do check out the Plotting Template in Append Mode and Plotting Template for Selected Corners video to learn the how-tos of these enhancements.
  Video Plotting Template in Append Mode and Plotting Template for Selected Corners
 Product Manual Virtuoso ADE Explorer User Guide
Subscribe to receive email notifications about our latest Custom IC Design blog posts. This upgrade is built with you in mind. Whether you're a long-time Virtuoso Studio user or just getting started, we'd love to know what you think. Share your feedback with us at custom_ic_blogs.
Happy Reading!
Udit Rajput and Yuan (PE) Li
