  3. Virtuoso Studio IC23.1 ISR12 Now Available
Virtuoso Release Team
Virtuoso Studio
IC Release
IC Release Blog Announcement
Custom IC
IC design
IC23.1
29 Jan 2025 • 2 minute read
Virtuoso Studio
Virtuoso Studio IC23.1 ISR12 production release is now available at Cadence Downloads. The README.txt file in the installation directory provides information about supported platforms and other release compatibility.
IC23.1 ISR12
Here are the highlights from the Virtuoso Studio IC23.1 release:
  • Specifying Plot Type for an Output (Virtuoso ADE Explorer and Virtuoso ADE Assembler)
    You can choose the plot type for an output in the Plot Target column of the Outputs Setup tab even before running the simulation.
  • Support for New vpwlfm Symbol in the Analog Library (Virtuoso ADE Explorer, Virtuoso ADE Assembler, and Virtuoso Schematic Editor)
    The analog library has been updated with a new symbol, vpwlfm. This symbol is independent piece-wise linear voltage source based on file for multiple signals.
  • Viewing Corner-Specific DCmatch Mismatch Summary (Virtuoso ADE Explorer and Virtuoso ADE Assembler)
    You can use the showDCMismatchSummaryTableUI environment variable to view the DCmatch mismatch summary through the Dcmatch summary report window instead of the results display window. This window lets you view corner-specific Dcmatch mismatch summaries in a tabular format.
  • Specifying Multi-PDK Environment Settings (Virtuoso RF Solution)
    You can specify one or more text files from which the environment settings are loaded.
  • What's New in Virtuoso Studio IC23.1 ISR12 (Application Notes)
