  3. Virtuoso Studio IC23.1 ISR7 Now Available
Virtuoso Release Team
Cadence blogs
Virtuoso Studio
IC Release Blog Announcement
Cadence Community
IC23.1
3 Jun 2024 • 1 minute read
Virtuoso Studio
Virtuoso Studio IC23.1 ISR7 production release is now available for download at Cadence Downloads. For information about supported platforms and other release compatibility information, see the README.txt file in the installation directory.
IC23.1 ISR7
Here are the highlights from the Virtuoso Studio IC23.1 release:
  • Defining Number of Sides of Polygons for Shape Simplification (Virtuoso MultiTech)
    You can select multiple instances and simultaneously change the port type, ball, or bump parameters.
  • Highlighting Selected Objects in Layout Canvas for LVS Models (Virtuoso MultiTech)
    In the Number of Points section in the Pre-Process tab, you can specify the number of sides for polygons to which shapes in an IC layout are to be converted.
  • Multi-Selection in the Components Sub-Tab (Virtuoso MultiTech)
    When you select a net or instance of an LVS model in the Virtuoso Electromagnetic Solver assistant, the corresponding geometry is highlighted in the layout canvas.
  • What’s New in Virtuoso Studio IC23.1 ISR7 (Application Notes)
