  3. Virtuoso IC6.1.7 ISR18 and ICADV12.3 ISR18 Now Availabl…
Virtuoso Release Team
IC
ICADV12.3
ADE
Layout
Virtuosity
IC6.1.7
Custom IC
Virtuoso IC6.1.7 ISR18 and ICADV12.3 ISR18 Now Available
21 Mar 2018 • 2 minute read
The IC6.1.7 ISR18
 and ICADV12.3 ISR18 production releases are now available for download at Cadence Downloads.
  • IC6.1.7 ISR18
  • ICADV12.3 ISR18
For information on supported platforms, compatibility with other Cadence tools, and a full list of issues fixed in each release, see:
  • IC6.1.7 ISR18 README
  • ICADV12.3 ISR18 README
* If any of the links above does not work, visit https://downloads.cadence.com and select the release name to access the README file for the release.
Here is a listing of some of the important updates made to IC6.1.7 ISR and ICADV12.3 ISR over the last few ISRs:
  • (ICADV12.3 Only) Area-based rule support in interactive routing (from ISR16)
    Define different rules for different design areas and allow the edited shapes in an area to be automatically adjusted based on the specified rules.
  • Enhanced eye diagram and measurement support (from ISR17)
    Create a centered or custom eye diagram and calculate new eye measurements, such as Max Eye Height and Max Eye Width.
  • Enhanced Update Binding support (from ISR16)
    Bind layout instances based on a .sip file, if the .net file is not available for some reason.
  • Ability to compare waveforms for digital signals (from ISR15)
    Use the new settings on Global Options for Waveform Comparison form to run waveform comparison for digital signals.
  • RF analyses support in reliability simulation (from ISR15)
    Use pss, pnoise, hb, and hbnoise to run RF analyses with reliability analysis.
  • New command-line IP selector support (from ISR15)
    Bring Virtuoso AMS block (config view) into the digital-centric, mixed-signal simulation setup to create netlists and configurations that are supported by Spectre AMS Designer.
For more details of these and all other new and enhanced features introduced over the last few ISRs, see:
  • IC6.1.7 What's New
  • ICADV12.3 What's New
Please send questions and feedback to virtuoso_rm@cadence.com.
To receive Virtuoso release announcements like this one, and other Virtuoso-related information, directly in your mailbox, type your email ID in the Subscriptions field at the top of the page and click SUBSCRIBE NOW.
