  3. Virtuoso IC6.1.7 ISR21 and ICADV12.3 ISR21 Now Availabl…
Virtuoso Release Team
Virtuoso IC6.1.7 ISR21 and ICADV12.3 ISR21 Now Available
10 Jul 2018 • 2 minute read
The IC6.1.7 ISR21
and ICADV12.3 ISR21 production releases are now available for download at Cadence Downloads.
  • IC6.1.7 ISR21
  • ICADV12.3 ISR21
For information on supported platforms, compatibility with other Cadence tools, and details of issues resolved in each release, see:
  • IC6.1.7 ISR21 README
  • ICADV12.3 ISR21 README
The links above are functional at the time of publishing. If you encounter any links that are now obsolete, visit https://downloads.cadence.com and select the release name you are interested in to access the related files.
Here is a listing of some of the important updates made to IC6.1.7 ISR and ICADV12.3 ISR over the last few releases:
  • Default Application to Open a Saved ADE State (from ISR21)
    Specify a default application where you want to open a saved ADE state. Use these while migrating to ADE Explorer or ADE Assembler.
  • Wildcard Syntax for Saving PCells in Netlist (from ISR21)
    Use wildcards to specify PCell operating point parameters on the Save Options form.
  • (ICADV12.3 Only) Display of Packet Name for WSP Tracks in Virtuoso Width Spacing Patterns (from ISR19)
    Use custom display packets for WSP tracks.
  • New Single Schematic Driven Simulation and Layout Flow in Virtuoso System Design Platform (from ISR19)
    Use a master schematic to drive both pre- and post-layout simulations and to create the package layout.
  • Enhanced eye diagram and measurement support (from ISR17)
    Create a centered or custom eye diagram and calculate new eye measurements, such as Max Eye Height and Max Eye Width.
  • (ICADV12.3 Only) Area-based rule support in interactive routing (from ISR16)
    Define different rules for different design areas and allow the edited shapes in an area to be automatically adjusted based on the specified rules.
  • Enhanced Update Binding support (from ISR16)
    Bind layout instances based on a .sip file, if the .net file is not available for some reason.
For more details of these, and all other new and enhanced features introduced in this release, see:
  • IC6.1.7 What's New
  • ICADV12.3 What's New
Please send questions and feedback to virtuoso_rm@cadence.com.
To receive Virtuoso release announcements like this one, and other Virtuoso-related information, directly in your mailbox, type your email ID in the Subscriptions field at the top of the page and click SUBSCRIBE NOW.
