  3. Virtuoso IC6.1.7 ISR22 and ICADV12.3 ISR22 Now Availabl…
Virtuoso Release Team
Analog Design Environment
ICADV12.3
ADE Explorer
ADE
Layout
IC6.1.7
Custom IC
Virtuoso IC6.1.7 ISR22 and ICADV12.3 ISR22 Now Available
3 Sep 2018 • 2 minute read
The IC6.1.7 ISR22
 and ICADV12.3 ISR22 production releases are now available for download at Cadence Downloads.
  • IC6.1.7 ISR22
  • ICADV12.3 ISR22
For information on supported platforms, compatibility with other Cadence tools, and details of issues resolved in each release, see:
  • IC6.1.7 ISR22 README
  • ICADV12.3 ISR22 README
The links above are functional at the time of publishing. If you encounter any links that are now obsolete, visit https://downloads.cadence.com and select the release name you are interested in to access the related files.
Here is a listing of some of the important updates made to IC6.1.7 ISR and ICADV12.3 ISR over the last few releases:
  • Faster Netlist Generation for Analog Components in a Mixed-Signal Design (from ISR22)
    Use the new Create spectre subckt for extracted view check box to generate an optimized netlist for analog components in a mixed-signal design. Not only does the new option improve the netlisting performance but it also skips the mixed-signal elaboration step for these cellviews, saving the overall simulator processing time.
  • Default Application to Open a Saved ADE State (from ISR21)
    Specify the default application where you want to open a saved ADE state. Use these while migrating to ADE Explorer or ADE Assembler.
  • Wildcard Syntax for Saving PCells in Netlist (from ISR21)
    Use wildcards to specify PCell operating point parameters on the Save Options form.
  • (ICADV12.3 Only) Display of Packet Name for WSP Tracks in Virtuoso Width Spacing Patterns (from ISR19)
    Use custom display packets for WSP tracks.
  • New Single Schematic Driven Simulation and Layout Flow in Virtuoso System Design Platform (from ISR19)
    Use a master schematic to drive both pre- and post-layout simulations and to create the package layout.
For more details on these and all the other new and enhanced features introduced in this release, see:
  • IC6.1.7 What's New
  • ICADV12.3 What's New
Please send questions and feedback to virtuoso_rm@cadence.com.
To receive Virtuoso release announcements like this one, and other Virtuoso-related information, directly in your mailbox, type your email ID in the Subscriptions field at the top of the page and click SUBSCRIBE NOW.
