  3. Virtuoso IC6.1.8 ISR3 and ICADVM18.1 ISR3 Now Available
Virtuoso Release Team
ICADVM18.1
ADE Explorer
Virtuoso Space-based Router
Interactive and Assisted Routing
Virtuoso RF
ADE
Layout
cadenceblogs
IC Release Blog
New in EDA
Virtuoso Layout Suite
Custom IC
IC6.1.8
30 Apr 2019 • 3 minute read
The
IC6.1.8 ISR3 and ICADVM18.1 ISR3 production releases are now available for download at Cadence Downloads.
  • IC6.1.8 ISR3
  • ICADVM18.1 ISR3
For information on supported platforms, compatibility with other Cadence tools, and details of key issues resolved in each release, see:
  • IC6.1.8 ISR3 README
  • ICADVM18.1 ISR3 README
The above links are functional at the time of publishing. If you encounter any links that are now obsolete, visit https://downloads.cadence.com and select the release name you are interested in to access the related files.
Here is a listing of some of the important updates made to IC6.1.8 and ICADVM18.1 for the ISR3 release:
  • Enhanced Design Planner Features (ICADVM18.1 Only)
    Use the enhanced Design Planner GUI to support an additional command—Generate Selected From Source—to allow selected schematic instances to be used for incremental virtual hierarchy generation, and Make Cell enhancements to allow more control on pin creation.
  • Create Fillets to Improve Manufacturability and Reliability (ICADVM18.1 Only)
    Create fillets to help prevent shock and vibration that might disrupt connections and prevent acid traps on design during fabrication. The new Fillet icon on the Metal Density toolbar now lets you create fillets on the shapes in the analog and high-speed circuits. In addition, the options in the Fillet tab of the Metal Density Options form lets you control how a fillet shape is created.
  • Create an FGR Automatically
    The AUTO option added to the Device field on the Wrap tab of the Create Guard Ring form now lets you create an FGR around selected devices automatically.
  • Save and Load the Options and Status Files
    Abstract Generator now saves information about each cell individually, in separate status files (.abstract.status). These status files are stored in the .abstract/<library name>/cellStatus directory in the current working directory.
    • Improved Reliability Options Form
      Use the revamped options of the Reliability Options form and get the benefit of the usability enhancements – regrouping of options in four tabs to keep the related options together.
    • Plot Signals in Datasheets using Plotting Templates
      The Replace Using Template option in the Create Datasheet form now lets you include the graphs in the datasheet from a plotting template.
      • Redesigned Stimuli Assignment Form
        • The renamed and redesigned Stimuli Assignment form helps in previewing the stimuli waveforms without creating a testbench while running a simulation.
          • Verify Mixed-Signal Design Projects
            Verify mixed-signal design projects by using the bi-directional connection between Virtuoso ADE Verifier and Cadence© vManagerTM Metric-Driven Signoff Platform, a digital verification tool.
            • Filter Trace Legends
              Use the Legend Filter form to apply filters to selectively view the traces that you want to work upon. This helps you to save a significant space from the trace legend area to view the traces better in the active graph window or subwindow.
              • Electro-Thermal Analysis in Legato Reliability Solution
                Enable the electro-thermal analysis on the Electro-Thermal tab of the Transient Options form to create a thermal model of the die based on the chip structure and thermal properties of the die stack.
              For more details on these and all the other new and enhanced features introduced in this release, see:
              • IC6.1.8 What's New
              • ICADVM18.1 What's New
              To receive Virtuoso release announcements like this one, and other Virtuoso-related information, directly in your mailbox, type your email ID in the Subscriptions field at the top of the page and click SUBSCRIBE NOW.
