  3. Virtuoso IC6.1.8 ISR4 and ICADVM18.1 ISR4 Now Available
Virtuoso Release Team
ICADVM18.1
ADE Explorer
Virtuoso Space-based Router
Interactive and Assisted Routing
Virtuoso RF
ADE
Layout
cadenceblogs
IC Release Blog
New in EDA
Virtuoso Layout Suite
Custom IC
IC6.1.8
17 Jun 2019 • 4 minute read
The
IC6.1.8 ISR4 and ICADVM18.1 ISR4 production releases are now available for download at Cadence Downloads.
  • IC6.1.8 ISR4
  • ICADVM18.1 ISR4
For information on supported platforms, compatibility with other Cadence tools, and details of key issues resolved in each release, see:
  • IC6.1.8 ISR4 README
  • ICADVM18.1 ISR4 README
The above links are functional at the time of publishing. If you encounter any links that are now obsolete, visit https://downloads.cadence.com and select the release name you are interested in to access the related files.
Here is a listing of some of the important updates made to IC6.1.8 and ICADVM18.1 for the ISR4 release:
  • New Automated Device-Level Layout Flow (ICADVM18.1 Only)
    Use the Auto Device P&R assistant to generate automatically placed and routed layouts.
  • Generation of Reusable Modgen Templates (ICADVM18.1 Only)
    Increase your layout productivity with the use of reusable Modgen templates that comprise a set of common Modgen parameters that can be reused to create a gridded layout of matching structures.
  • Support for Stack Devices in Modgens (ICADVM18.1 Only)
    Use the GPE and GPM assistants to visualize and manipulate stack devices within Modgens to achieve higher circuit performance goals in advanced node PDKs.
  • Trunk Mesh Routing Flow (ICADVM18.1 Only)
    Use the new Trunk Mesh Routing Configuration form to configure trunk to trunk mesh routing for a Layout EXL device-level design.
  • Tree Routing Flow (ICADVM18.1 Only)
    Automatically identify and route mesh, ring, and tree structures in advanced node device-level designs using the new Tree Route Flow.
  • Automatic Trunk Generation Using the Trunk Subform (ICADVM18.1 Only)
    Now generate trunks automatically for device-level designs using the trunk generation option under the Generation group box of the Trunk subform.
  • Top-level Editing of Virtual Hierarchy Clones (ICADVM18.1 Only)
    Perform basic edits at top level—stretch, chop, and area boundary adjustment—for a virtual hierarchy clone.
  • Support for Deleting Color of Connected Shapes (ICADVM18.1 Only)
    Use the Delete color on connected shapes option on the Multiple Patterning Options form to delete the color on shapes connected to the selected shape.
  • Color Locking of Synchronous Clones (ICADVM18.1 Only)
    Use the Lock Colors drop-down in the Multiple Patterning toolbar to lock (or unlock) all colors on all (or selected) layers.
  • Support for Instance-Level Local Scoping
    Use the MTS Options form to now enable local scoping at an instance level.
  • Support for New EM Data Source
    Use the iRCX-EM file as a new data source for EM without needing to update the existing EAD technology file or first converting to an ICT-EM file.
  • Enhanced EM/IR Analysis for Wide Pins
    Specify multiple current injection points on wide metal pin for accurate EM and IR drop analysis.
  • Support for Maintaining the PDK Version for Express Pcells
    Define a library version SKILL variable in the libInit.il of a PDK to be notified if Pcells currently in the cache are out of date.
  • Support for Enabling Express Pcells for Specific Libraries
    Control which Pcell libraries are included or excluded for cache operations.
For more details on these and all the other new and enhanced features introduced in this release, see:
  • IC6.1.8 What's New
  • ICADVM18.1 What's New
To receive Virtuoso release announcements like this one, and other Virtuoso-related information, directly in your mailbox, type your email ID in the Subscriptions field at the top of the page and click SUBSCRIBE NOW.
