  3. Virtuoso IC6.1.8 ISR5 and ICADVM18.1 ISR5 Now Available
Virtuoso Release Team
ICADVM18.1
ADE Explorer
Virtuoso Space-based Router
Automated Device-Level Placement and Routing
Automatic Placement
Interactive and Assisted Routing
Virtuoso RF
ADE
Mixed-Signal
Layout
cadenceblogs
IC Release Blog
New in EDA
Virtuoso Layout Suite
Custom IC
IC6.1.8
ADE Assembler
30 Jul 2019 • 2 minute read
The
IC6.1.8 ISR5 and ICADVM18.1 ISR5 production releases are now available for download at Cadence Downloads.
  • IC6.1.8 ISR5
  • ICADVM18.1 ISR5
For information on supported platforms, compatibility with other Cadence tools, and details of key issues resolved in each release, see:
  • IC6.1.8 ISR5 README
  • ICADVM18.1 ISR5 README
The above links are functional at the time of publishing. If you encounter any links that are now obsolete, visit https://downloads.cadence.com and select the release name you are interested in to access the related files.
Here is a listing of some of the important updates made to IC6.1.8 and ICADVM18.1 for the ISR5 release:
  • Virtual Hierarchy Generation (ICADVM18.1 Only)
    Use Update Virtual Hierarchies to enable transfer of virtual hierarchies from the source to the target cellviews.
  • Virtual Hierarchy Types (ICADVM18.1 Only)
    Easily identify the different types and placement status of virtual hierarchies in a design - depending on the color and line style used by the bounding box for each virtual hierarchy.
  • Automatic Adjustment of an Area Boundary (ICADVM18.1 Only)
    Automatically adjust the area boundary of a virtual hierarchy when moving instances outside a virtual hierarchy and adding instances to a virtual group.
  • Scenic Ratio Capabilities (ICADVM18.1 Only)
    Use the Scenic Net column in the Navigator assistant to easily visualize critical scenic nets and improve their performance.
  • Automatic Generation of Hierarchy (ICADVM18.1 Only)
    Use the Auto-Generate Hierarchy functionality to configure, specify bindings, and generate top blocks and soft blocks in the layout canvas. This functionality lets you quickly generate a physical hierarchy by applying common parameters.
  • Free Area Pin Group Guides
    The Free Area option in the Pin Group Guide form lets you place pins in the free area within the PR boundary.
  • Pivot Reports for ADE Assembler Results
    Export ADE Assembler results to an Excel format that can be readily used to create pivot tables and graphs for a better presentation and analysis of the simulation results.
For more details on these and all the other new and enhanced features introduced in this release, see:
  • IC6.1.8 What's New
  • ICADVM18.1 What's New
To receive Virtuoso release announcements like this one, and other Virtuoso-related information, directly in your mailbox, type your email ID in the Subscriptions field at the top of the page and click SUBSCRIBE NOW.
