  3. Virtuoso Studio IC23.1 ISR16 Now Available
Virtuoso Release Team
IC 23.1
Virtuoso Studio
IC Release
IC Release Blog
Custom IC
IC design
25 Sep 2025 • 2 minute read
Virtuoso Studio
Virtuoso Studio IC23.1 ISR16 production release is now available at Cadence Downloads. The README.txt file in the installation directory provides information about supported platforms and other release compatibility.
IC23.1 ISR16
Here are the highlights from the recent Virtuoso Studio IC23.1 ISR releases:
  • Updating Model Files while Migrating maestro Views as Part of Schematic Migration (Virtuoso Custom Design Migration)
    When migrating a Virtuoso design from one technology file to another, as part of the schematic migration process you can now update the target model files in the migrated maestro views. For this, create a model mapping file that provides details about which section in the source model file maps to which section of the target model file, and modify the configuration file to add options specifying name and location of the model configuration file. The migration happens when the cells and views of the source library are processed in step one of the schematic migration process.
  • Specifying Plot Type for an Output (Virtuoso ADE Explorer and Virtuoso ADE Assembler)
    You can choose the plot type for an output in the Plot Target column of the Outputs Setup tab, even before running the simulation.
  • Support for New vpwlfm Symbol in the Analog Library (Virtuoso ADE Explorer, Virtuoso ADE Assembler, and Virtuoso Schematic Editor)
    The analog library has been updated with a new symbol, vpwlfm. This symbol is an independent piece-wise linear voltage source based on the file for multiple signals.
  • Viewing Corner-Specific DCmatch Mismatch Summary (Virtuoso ADE Explorer and Virtuoso ADE Assembler)
    You can use the showDCMismatchSummaryTableUI environment variable to view the DCmatch mismatch summary through the Dcmatch summary report window instead of the results display window. This window lets you view corner-specific Dcmatch mismatch summaries in a tabular format.
  • Specifying Multi-PDK Environment Settings (Virtuoso RF Solution)
    You can specify one or more text files from which the environment settings are loaded.
  • What's New in Virtuoso Studio IC23.1 ISR16 (Application Notes)
