  3. Virtuoso Studio IC25.1 ISR7 Now Available
Virtuoso Release Team
IC25.1
Cadence blogs
Virtuoso Studio
IC Release Announcement blog
IC Release Blog
29 Jul 2026 • 5 minute read
Virtuoso Studio
The Virtuoso Studio IC25.1 ISR release is now available at Cadence Downloads. The README.txt file in the installation directory provides information about supported platforms and other release compatibility.
IC25.1
Here's a list of the highlights from the Virtuoso Studio IC25.1 ISR release:
  • Generating Design Area Summary (Virtuoso ADE Artist, Virtuoso ADE Assembler)
    Evaluate device area results using the Area Goal Summary form, which consolidates area results for devices to compare areas across corners and filter by corner name. Use this form to improve design analysis efficiency and accelerate area-driven optimization decisions.
  • Customizing Area Goal Calculation (Virtuoso ADE Artist, Virtuoso ADE Assembler)
    Use the includeInstances and excludeInstances arguments in the getCellArea SKILL function to include or exclude specific instances for the calculation of the area of a design.
  • Modernized Datasheet Experience with Flexible Customization (Virtuoso ADE Artist, Virtuoso ADE Assembler, Virtuoso ADE Explorer)
    The datasheets have been enhanced for an interactive viewing experience. They offer a more intuitive and streamlined way to review simulation results. The tabbed view makes it easier to navigate across different sections and analyze results efficiently. The filtering and sorting capabilities help you quickly locate and analyze specific data and provide column visibility control so you can customize the displayed information.
  • Measuring TDECQ Using the Eye Diagram Assistant (Virtuoso Visualization and Analysis XL)
    Use the TDECQ tab in the Eye Diagram assistant to measure Transmitter and Dispersion Eye Closure Quaternary (TDECQ) and other important metrics for a PAM4 optical signal.
  • Automatic Checking and Updating of IC Component Thickness Values (Virtuoso Heterogenous Integration)
    To avoid manually specifying the thickness of IC instances and to ensure consistency between IC layout instances and their referenced IC models, the Settings tab in the Multiphysics Analysis toolbar provides automated support for checking and updating thickness values. The Check IC Thickness and Update IC Thickness options automatically detect thickness mismatches between IC instances and their referenced models and synchronize thickness values across package design.
  • Retaining Design Hierarchy of a Plotted Signal (Virtuoso ADE Artist, Virtuoso ADE Assembler)
    The design hierarchy of plotted signals is now retained even after resubmitting the simulation.
  • Saving and Restarting Unfinished Error Points (Virtuoso ADE Artist, Virtuoso ADE Assembler)
    The save and restart flow saves the state files generated during the simulation run for transient analysis. This enables you to directly run the simulation for a specific history item using the Rerun Unfinished/Error Points option from the context menu of the History tab. The Enable save/restart flow for transient analysis option in the run options form enables the feature by default.
  • Adding Reliability Degradation Parameters (Virtuoso ADE Artist, Virtuoso ADE Assembler, Virtuoso ADE Explorer)
    Use relexpr expressions to add the reliability degradation parameters that can help retrieve information about the maximum, minimum, or the number of parameters violating the reliability threshold. The relexpr expressions can be specified in the Outputs Setup pane.
  • Optimizing Duplicate Simulation Runs in Reliability Scenarios (Virtuoso ADE Artist, Virtuoso ADE Assembler, Virtuoso ADE Explorer)
    Simulation runs in reliability scenarios are now optimized by identifying the results of unique corners and reusing them across design points. This enables you to avoid duplicate runs because the results of a scenario can be reused in other scenarios when running fresh or stress-stage simulations in the aging scenario.
  • Searching and Replacing Outputs (Virtuoso ADE Artist, Virtuoso ADE Assembler, Virtuoso ADE Explorer)
    The search and replace feature enables you to modify the outputs listed in the Outputs Setup tab in your external text editor. This ensures efficient customization of the outputs.
  • Viewing worst-case Violations (Virtuoso ADE Artist, Virtuoso ADE Assembler, Virtuoso ADE Explorer)
    You can display only those violations that have the highest value per net or instance across corners and sweep points by selecting the Worst Case option. This enables you to identify worst cases, such as the longest duration of violations over corners, the maximum peak value of violations, and the maximum violating ratio per net or instance.
  • Optimizing Design Area (Virtuoso ADE Artist, Virtuoso ADE Assembler, Virtuoso ADE Explorer)
    You can optimize the area occupied by devices in a design by defining area specifications. To define area specifications, create a configuration file containing area formulas, add output expressions, and specify the SKILL function, getCellArea, to calculate the area.
  • What's New in Virtuoso Studio IC25.1 ISR7 (Application Notes)
  • Virtuoso Studio IC25.1 New
For questions or feedback, write to virtuoso_rm@cadence.com.
To receive Virtuoso Studio release announcements like this one and other Virtuoso Studio-related information directly in your mailbox, select the SUBSCRIBE check box in the Subscription box.
