  3. Virtuoso: The Next Overture – DRD Launches New Interfac…
Pallabi R
Pallabi R
Virtuoso Next
Virtuoso Overture
Virtuoso New Design Platform
Virtuoso Advanced Release
DRD
New in EDA
Custom IC
Virtuoso: The Next Overture – DRD Launches New Interface
7 Aug 2018 • 3 minute read
The new release of the Virtuoso platform (*ICADVM18.1) offers groundbreaking analysis capabilities and an innovational new simulation-driven layout for more robust and efficient design implementation as well as extending our support for the most advanced process technologies. With this solution, we are able to significantly improve productivity through advanced methodologies and provide the most comprehensive set of solutions in the industry with an interoperable flow across chip, package, module and board.
*This feature will also be available in IC6.1.8 for mature nodes.
If you’ve been anywhere near the Cadence news buzz the last couple of months, you must have heard about the DRD relaunch, we’re sure. The research and development team of the Design Rule Driven (DRD) tool had long been looking into the areas of a new software architecture and new interaction paradigms to make in-design verification smarter and more efficient than ever. The team looked closely at the existing challenges and decided to rebuild DRD from the ground up—a revamp, so to speak. DRD now brings to you a fresh new look and a lot more. Let’s have a closer look.
Smart Usability with High Performance
You might ask us to explain how the new DRD will augment your experience and why you should opt for it. Well, then, let us highlight a few offerings of the tool.
  • Performance Boost: The new DRD boasts of a significant enhancement in performance, and the results are indeed fascinating. Now, you can edit a layout with DRD ON at the same pace as when DRD is OFF. Some of the features responsible for boosting the performance of the new tool include:
    • Optimized area loading for checking
    • Sliding window-based checking
    • Context-based checking while working with instances and sets of objects
And we have numbers to back us up in our claims to enhanced DRD performance.
  • Smart Use Models for Improved Visualization: The new DRD is equipped with smart use models that offer an improved error visualization and streamlined debugging experience. Some of the highlights include:
    • Incremental display of violations
    • Enhanced display of off-screen violations
    • Option to limit the number of halos
    • Arrow and text size as proportional to the shape size
  • Consolidated Interface: The new DRD toolbar offers access to the simplified and consolidated interface in just one click. This new interface houses the interactive and batch checking options in one place instead of two separate forms.
  • Enhanced User Control: The new DRD gives you more control over hierarchy and the constraint and layer filters for design verification.
For more information on the new DRD interface and its use models, do watch the following videos available on Cadence Support portal:
  • Introduction to the New DRD User Interface
  • Using the DRD Incremental Violation Display Feature
  • Using the DRD Sliding Window
Sounds exciting? Watch out for our upcoming Virtuoso platform ICADVM18.1 and IC6.1.8 releases, and then take a fresh new look at the new DRD and start editing with DRD ON with the same pace as in DRD OFF.
For more information on What’s New in Virtuoso ICADVM18.1 release, see What's New in Virtuoso. For more information on Cadence Custom IC/Analog/RF Design products and solutions, visit www.cadence.com.
For more information on the New Virtuoso Design Platform, or if you have any questions or feedback on the features covered in this blog, please contact team_virtuoso@cadence.com.
If you would like to receive similar updates about what new and exciting features are being built into Virtuoso for our upcoming Advanced Nodes and Advanced Methodologies releases, type your email ID in the Subscriptions field at the top of the page and click SUBSCRIBE NOW.
Pallabi Roy and Navit Rana (Team Virtuoso)
